How to add inertial lift force and Dean force
Hi everybody,
I m doing simulation for inertial focusing. I need to see the effect of inertial lift force and dean force on particle. I m just wanted to know where these forces can be defined. I tried to add them in particle tracing-> forces. still no use.
Appreciate help from someone.
Thanks in Advance.
3 Replies Last Post 2016/11/29 20:29 GMT-5
Hello Md Usuf
Posted: 10 years ago 2015/12/17 21:55 GMT-5
Have you worked out any approach to solve the problem? I have same questions with you.Need your
help,thank you!
Hi, Have you worked out any approach to solve the problem? I have same questions with you.Need your help,thank you!
Posted: 10 years ago 2016/04/08 5:11 GMT-4
i tried to add ode for force equations and still could not solve. if you got let me know, we can discuss
Posted: 9 years ago 2016/11/29 20:29 GMT-5
Hi Chengjun,
I have the same problem now that I could not add inertial lift force and Dean force.
I wonder if you have figured it out and I appreciate it very much if you could help me.
Chen Zezhou
Hi Chengjun, I have the same problem now that I could not add inertial lift force and Dean force. I wonder if you have figured it out and I appreciate it very much if you could help me. Regards, Chen Zezhou
