2D Axisymmetric Helmholtz Coil with Infinite Element Domains
Posted 2015/10/29 17:11 JST Low-Frequency Electromagnetics, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.1 2 Replies
Hi Folks,
I have used infinite element domains extensively in 3D models with no issue. I have a 2D Axisymmetric simulation I wish to run, simulating the field from a Helmholtz coil.
The model solves fine without infinnite element domains, but when I add the infinite element layer to the problem, I get an incorrect result. I seem to recall an additional boundary condition needs to be added to the model in 2D axisymmetric in order to get correct results with infinite elements, but cannot recall which one. I have attached the model.
Any pointers greatly appreciated!
Mark
p.s. the attached model has the infinite elements added in and you can see the incorrect result. It is simple enough to remove the infinite elements, re-solve and see the correct result.
Mark
2 Replies Last Post 2015/11/02 16:15 JST
