Math lab connection with comsol
Dear Ivar,
I am working with comsol 3.5 a. I need to know the version of math lab that I want to installed inorder to work with comsol math lab connection. Please give me an answer for me.
Manjula
5 Replies Last Post 2010/09/21 2:33 GMT-4
Posted: 2 decades ago 2010/09/16 17:00 GMT-4
I have used 3.5a with both a matlab 2007 and a 2009 version without niticed difficulties (due to compatibility ;)
Hi I have used 3.5a with both a matlab 2007 and a 2009 version without niticed difficulties (due to compatibility ;) -- Good luck Ivar
Posted: 2 decades ago 2010/09/17 10:55 GMT-4
Hi Ivar,
Do you know how can i redirect Comsol 3.5a to Matlab 2007 if i had installed both softwares before???
Thank you,
Ivette.
Hi Ivar, Do you know how can i redirect Comsol 3.5a to Matlab 2007 if i had installed both softwares before??? Thank you, Ivette.
Posted: 2 decades ago 2010/09/17 11:10 GMT-4
hi my dear
first of all you should read the documentaion
if you want to install matlab with comsol , in v3.5 you can use matlab 2006-7 A&B
after that, first, you should install matlab then comsol
and in the setup of the comsol ,you browse the root of matlab in the directory
best regard
hi my dear first of all you should read the documentaion if you want to install matlab with comsol , in v3.5 you can use matlab 2006-7 A&B after that, first, you should install matlab then comsol and in the setup of the comsol ,you browse the root of matlab in the directory best regard
Posted: 2 decades ago 2010/09/17 13:36 GMT-4
I'm working with comsol 3.5a with Matlab 2010 and worked fine only after I run the latest patch for comsol 3.5a
The way i connect matlab is the following
click the properties on comsol desktop shurtcut and and add the word matlab it looks like this
C:\COMSOL35a\bin\comsol64.exe matlab
then go to
c:\COMSOL35a\bin\ and change the line in the comsol.opts to something similar
mlroot=C:\Program Files\MATLAB\R2010a
Thats the hard way of doing it.
I'm sure there must be an easier way!
good luck
Giorgos
Hi, I'm working with comsol 3.5a with Matlab 2010 and worked fine only after I run the latest patch for comsol 3.5a The way i connect matlab is the following click the properties on comsol desktop shurtcut and and add the word matlab it looks like this C:\COMSOL35a\bin\comsol64.exe matlab then go to c:\COMSOL35a\bin\ and change the line in the comsol.opts to something similar mlroot=C:\Program Files\MATLAB\R2010a Thats the hard way of doing it. I'm sure there must be an easier way! good luck Giorgos
Posted: 1 decade ago 2010/09/21 2:33 GMT-4
On the mac you do pretty much the same... go to the file /Applications/COMSOL35a/bin/comsol and change the MLROOT=${MLROOT:=/Applications/MATLAB_R2010a.app} to what ever version you have...
