Equation in Comsol
I am doing simulation on nozzle and diffuser and I need to find the pressure loss coefficient,which the formula will be:
kd=(vb/va)
where vb is inlet velocity and va is outlet velocity
The Vb and Va is the variable calculated form comsol.
may i ask is it possible to insert (vb/va) function in comsol and to calculate for Kd?
Thanks.
2 Replies Last Post 2010/09/23 8:37 GMT-4
Posted: 2 decades ago 2010/09/21 6:04 GMT-4
You define your new variable kd as Vb/Va and then you plot the value kd over the region you want
Hi You define your new variable kd as Vb/Va and then you plot the value kd over the region you want -- Good luck Ivar
Posted: 2 decades ago 2010/09/23 8:37 GMT-4
Thanks Ivar,
but my problem is Va is velocity at the entrance(inlet boundary) while Vb is velocity at exit (outlet boundary).
I have tried to go for boundary expression,where i select
inlet boundary=Va
outlet boundary=Vb
then go to gloabl expression ,kd= (Vb/Va)
but when I plot using cross section plot, I type in Kd at expression,
It give me blank graph.
Issit possible to have mean velocity at Va and Vb as the velocity value varies along the vertical line. (laminar flow)
thanks.
Thanks Ivar, but my problem is Va is velocity at the entrance(inlet boundary) while Vb is velocity at exit (outlet boundary). I have tried to go for boundary expression,where i select inlet boundary=Va outlet boundary=Vb then go to gloabl expression ,kd= (Vb/Va) but when I plot using cross section plot, I type in Kd at expression, It give me blank graph. Issit possible to have mean velocity at Va and Vb as the velocity value varies along the vertical line. (laminar flow) thanks.
