Eigenfrequency analysis problem
Posted 2015/11/26 3:52 GMT-5 Acoustics & Vibrations, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers, Structural Mechanics 3 Replies
I'm dealing with a nano rod vibration.
I want to know the displacement of some point on the eigen mode. (0.5 L, 0.125 L, .....)
However, I found that I can't find the same value that is I will get different answer after evaluation (on all the same condition).
ex.
sol.1 : 700Hz 20um
sol.2 : 700Hz 30um
The following is the processes I did,
Study: eigenfrequency
desired number: 30
after compute
use cut point 3D set some point in the center of rod but at different L
use derived value, Point Evaluation , then change the Data set to cut point 3D
then find u, v, w
the result is that i can't find the totally consistent answer in two time~~
(I thing is not the mesh problem)
L=length of the rod.
Thank you very much.
HW
ex.
sol.1 : 700Hz 20um
sol.2 : 700Hz 30um
desired number: 30
after compute
then find u, v, w
HW
3 Replies Last Post 2015/12/09 1:57 GMT-5
