User defined material property file *.xml
Posted 2010/09/21 9:11 GMT-4 7 Replies
I found it from a benchmark example, but do not konw how to bulid it by myself.
The webpage does not allow me to upload the original xml, so I save it as a pdf file.
normally you define it within COMSOL in the librbary module by defning a nw material and then defining the piecewise functions therein
I am calculating the transient field norm on an STM junction using electromagnetic waves. The dielectric constant of silver for the laser I am using is -27+.4*j. If I use time harmonic it solves no problem but if I use transient, which is what I need, it gives me:
Error:
Undefined_value_found_Linsolv
NaN_or_Inf_found_when_solving_linear_system_using_SOR
If I use -27 it still gives me the error but if I use 5+.4*j it solves no problem. Does anybody know why it doesn't like -27+.4*j in transient calculations?
Thank you in advance.
Alejandro
Yes, I know how to define material property in material libary, but I do not know how to bulid the *.xml file, which can be used as a independent file or seperated file. It is very convenient if we can define the properties in a seperated file.
indeed there is no save material file, but you can create it within COMSOL, put the material into a custom library in xml format and then you will find the file in your .../users.../.comsol directory.
This is valid for 3.5, in V4.0a I agree there seem to be no way to generate such a xml file, allthough COMSOL v4 can import one. The default format is the .mph, which is a zip type file, but therein the materials data is already reformatted into a propretary COMSOL xml format I see
Suggested Content
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - BLOG Adding Information to Materials in User-Defined Material Libraries
- KNOWLEDGE BASE Modeling of Step Transitions
- BLOG Efficiently Assign Materials in Your COMSOL Multiphysics® Model
- FORUM Delete user defined material
