Electric field around a single wire
Good morning everyone, and apologies if this question is trivial, but I am very new to Comsol and I need a bit of help...
I would like to model the electric field surrounding a single wire. The geometry is clearly not a problem, but I can't figure it out what kind of solver to use, or what kind of boundaries.
I tried the "electric current" with a voltage and a ground assigned to the start and end of the wire but is did not seem to work.
Going on the forum, I saw you could use the MEF properties, but I don't really know how...
Thanks in advance!
1 Reply Last Post 2015/12/02 21:32 GMT-5
Posted: 10 years ago 2015/12/02 21:32 GMT-5
I used the AC/DC module. Check out my post titled "Help with "Charged particle tracing module"", in which I have also attached my model file. That could help.
Hi, I used the AC/DC module. Check out my post titled "Help with "Charged particle tracing module"", in which I have also attached my model file. That could help. Thanks
