Varying Boundary Conditions on Restart
Posted 2010/09/23 11:12 GMT-4 0 Replies
But, during the .5 second tunnel start-up, I do not know the heatflux. So, during that time I specify an ambient temperature and use a "temperature" BC and then the model reacts to the ambiet temperature. That part works.
For the next 1.5 seconds, my goal is to apply a heatflux (specified by a function) and have the model start where it left off, and react to the heatflux. So, I change the BC to "Heatflux" and specify the function for heatflux as a function of time. I then choose to restart where the "initial value" is the "current solution", and the "values of variables not solved for and linearization point" is the "current solution".
The problem is that the results show that the temperature going forward is reset to the initial conditions instead of running from the BC change over pint. Any thoughts?
Hello Ted Earp
