Relative permittivity of Gold at a frequency of 104 MHz
I need the value of the relative permittivity of Gold at a frequency of 104 MHz. I found values at optical wavelengths.
Thanks.
Nadia
3 Replies Last Post 2015/12/04 16:12 GMT-5
Posted: 10 years ago 2015/12/03 13:24 GMT-5
Hi Nadia,
the relative permittivity of gold (and most metals) at 104 MHz is pretty meaningless because the skin depth is less than a micrometer.
What exactly do you think you need it for?
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi Nadia, the relative permittivity of gold (and most metals) at 104 MHz is pretty meaningless because the skin depth is less than a micrometer. What exactly do you think you need it for? Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 10 years ago 2015/12/04 11:25 GMT-5
Dear Edgar,
Thank you for your reponse.
It is used for SAW (Surface Acoustic Wave) sensor. The interdigitated electrodes and the sensing zone are covered with Gold.
Nadia.
Dear Edgar, Thank you for your reponse. It is used for SAW (Surface Acoustic Wave) sensor. The interdigitated electrodes and the sensing zone are covered with Gold. Best regards, Nadia.
Posted: 10 years ago 2015/12/04 16:12 GMT-5
Nadia,
I assume that the gold coatings are much thicker than the skin depth at 104 MHz. So an impedance BC would typically by sufficient for the electrodes.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Nadia, I assume that the gold coatings are much thicker than the skin depth at 104 MHz. So an impedance BC would typically by sufficient for the electrodes. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
