Internal Convection in a box with heat transfer
Wesden Almeida Borges
Hello everybody!
I have a problem when modelling convection in a close box (rectangular shape) using general heat transfer module and weak compressible navier-stokes module coupled. I wanna know the profiles of heat flux and velocities on the fluid (argon, gas) but... My models don't converge... I think this can be solved in a simple mode, but i really don't figure out, yet. Can anyone post a solved model like this?
Description of my model:
Rectangular box, (0,80 m in x, 2,8 m in y)
Material Library: Argon (gas form)
General Heat Tranfer
Physics: default
convective box checked, velocity field marked as "u" and "v", Pa = 1[atm];
initial temperature=25[degC];
Bondary settings: botton: Temperature=(25+0.7*t[1/s])[degC]; all others: Insulation
Weakly Compressible Navier-Stokes
physics: all default, plus Fy=-9.8[m/s^2]*rho_chns
stabilization tab: all default
initial: u,v =0 (both), Po=1[atm]
Bondary Settings: wall, no slip (all them)
The time evolution that I tried was 100 seconds
I've already tried:
- Refining meshes
- Changes the solver
- Using a bondary condiction of heat flux instead Temperature (in general heat transfer, botton of box)
I always only find this message:
Error:
Thanks for reading, sorry for the long text. :)
3 Replies Last Post 2010/10/06 5:09 JST
Posted: 1 decade ago 2010/09/28 17:22 JST
Just some quick questions: did you try with setting a point pressure to 1atm as well?
or pressure=0. In case of natural convection I usually see people have problem with pressure setting of NS. Did you check what part of the model is not converging: fluid or Heat transfer?
Just some quick questions: did you try with setting a point pressure to 1atm as well? or pressure=0. In case of natural convection I usually see people have problem with pressure setting of NS. Did you check what part of the model is not converging: fluid or Heat transfer?
Posted: 1 decade ago 2010/09/29 5:24 JST
Hello, Danial!
I ever tried setting initial pressure = 1 atm, at initial tab (chns)... can I set this in other way?
If I model only using the general heat transfer, it can work, but I cannot get the velocity profile of fluid in internal convection... so I guess the problem is on Navier-Stokes modelling... the error message returned is that what I mentioned...
Thanks for help!
Hello, Danial! I ever tried setting initial pressure = 1 atm, at initial tab (chns)... can I set this in other way? If I model only using the general heat transfer, it can work, but I cannot get the velocity profile of fluid in internal convection... so I guess the problem is on Navier-Stokes modelling... the error message returned is that what I mentioned... Thanks for help!
Posted: 1 decade ago 2010/10/06 5:09 JST
Hello!
Anyone have a model at least similar to that I discribed above?
My model still doesn't work, and the problem isn't too hard, I think...
best regards,
Hello! Anyone have a model at least similar to that I discribed above? My model still doesn't work, and the problem isn't too hard, I think... best regards,
