COMSOL could modulate the failare inside of the material?
I have one question. What will happens when the simulating electric field will increase the withstand value of the material (isolation). Will the comsol modulate the failure (breakdowns) proces inside in the material by itself?
2 Replies Last Post 2010/10/04 5:20 GMT-4
Posted: 2 decades ago 2010/10/01 3:11 GMT-4
you would need to define the preabkown process physics yourself, I can imagine that you set a non linear condition to increase the resitivity if the field become too large and then see how this "propagates" through your material. Take a look at the example(s) of fatigue and crack propagation in solids, it could give you some ideas
Hi you would need to define the preabkown process physics yourself, I can imagine that you set a non linear condition to increase the resitivity if the field become too large and then see how this "propagates" through your material. Take a look at the example(s) of fatigue and crack propagation in solids, it could give you some ideas -- Good luck Ivar
Posted: 2 decades ago 2010/10/04 5:20 GMT-4
Thanks a lot for advantage.
