What if turbulent flow is modeled using laminar flow
Dear all,
I have the following questions:
1) What if a turbulent flow is modeled using laminar flow?
2) How different will the results of turbulent flow and laminar flow models be (note that the correct model is turbulent flow)?
Akim
4 Replies Last Post 2015/12/24 2:46 JST
Posted: 10 years ago 2015/12/23 18:51 JST
It all depends... in particular what features you are looking at. In some cases the difference might not affect some coarse features; in other cases the results won't just be different but will be WRONG!.
Easiest way to answer is to run simulations with both laminar and turbulent models and compare the features you are interested in.
If you want more advice it would help to describe a bit more about your geometry, what other physics are involved, what the purpose of the model is - what features you are interested in. And not least, what scale and Reynolds number you are working at.
It all depends... in particular what features you are looking at. In some cases the difference might not affect some coarse features; in other cases the results won't just be different but will be WRONG!. Easiest way to answer is to run simulations with both laminar and turbulent models and compare the features you are interested in. If you want more advice it would help to describe a bit more about your geometry, what other physics are involved, what the purpose of the model is - what features you are interested in. And not least, what scale and Reynolds number you are working at.
Posted: 10 years ago 2015/12/24 0:18 JST
If the flow is turbulent then using a laminar flow model should not converge. If it does then you may be using an excessively coarse mesh, too much stabilization, or loose convergence tolerances. Unsteady vortices should be triggered in the model but they cannot be resolved with any reasonable mesh resolution. That’s one of the things a turbulent model does.
Nagi Elabbasi
Veryst Engineering
If the flow is turbulent then using a laminar flow model should not converge. If it does then you may be using an excessively coarse mesh, too much stabilization, or loose convergence tolerances. Unsteady vortices should be triggered in the model but they cannot be resolved with any reasonable mesh resolution. That’s one of the things a turbulent model does. Nagi Elabbasi Veryst Engineering
Posted: 10 years ago 2015/12/24 2:45 JST
Thank you all. I have natural convection in oil with low viscosity and Rayleigh number is close to critical value of 10^6. So to be on the safe side should I use turbulent model? I have internal flow and I am using Algebraic yPlus.
Akim
Thank you all. I have natural convection in oil with low viscosity and Rayleigh number is close to critical value of 10^6. So to be on the safe side should I use turbulent model? I have internal flow and I am using Algebraic yPlus. Regards, Akim
Posted: 10 years ago 2015/12/24 2:46 JST
Sorry, Rayleigh number is close to 10^9.
