Hello Hyunjae Lee
                                9 years ago
                                2017/02/14 8:11 GMT-5
                                                    Hello everyone,
isn't there any answer or help?
I have the same problem, that comsol just uses the RAM between 30-50GB instead of 110GB.
The predefinde aplication work fine, they just use 3-5Gb of RAM and i had other Siumulations running with at least 100GB working.
                            Hello everyone,
                                Jeff Hiller
        COMSOL Employee
                                9 years ago
                                2017/02/14 16:00 GMT-5
                                                    Hello Bernd,
In my limited understanding of how these things work, the software calls for the OS to allocate memory in chunks before it can use that memory, so that allocated memory increases in steps, not continuously.
Is it possible that while up to that point in this particular solution process only 30-50GB have been needed, suddenly, say, an additional 100GB (which you don't have) is requested of the OS for the next step of the solution? This would explain why you run out of memory without ever getting close to "saturating" the 110GB.
                            Hello Bernd,
                                9 years ago
                                2017/02/14 16:14 GMT-5
                                                    Thank you very much Jeff for your explanation.
I also would like to add one point that you may encounter. When I had a crashed job because of this Out of Memory error, I noticed that the allocated RAM won't be released if I only stopped and closed that job. To get all those allocated RAM free, I restarted my computer but recently I found just close all COMSOL programs would be fine enough.
Just let you guys know if you are stuck at that point.
Thanks a lot.
Yi
Thanks a lot.
Yi
