Does Comsol4 have the function of Time-integral?
Posted 2010/10/15 17:15 GMT-4 Version 4.1, Version 4.2, Version 4.2a 8 Replies
If I want to do an Integration at a range of time, How should I do?
this has been discussed a few times, try a search on the Forum, but I cannot remember the "good" solution, as I do not believe there is a "time integration" operator as for the space integration.
In som cases you can change the time variable to a space variable, if you can adapt the equations
Thanks Ozgur, I forgot to search on the KB, I was sure it was somewhere ;)
see www.comsol.com/support/knowledgebase/913/
Right on, Ozgur, and in release 4.2a we have some nice news on this topic:
New additional time-dependent solutions operators that you can use for results evaluation, for example:
- timeint() for time integration
- timeavg() for time averages
4.2a will start shipping end of this week.
Niklas
I was wondering where may I find the time integral function timeint()? It would be great if you may drop quick tips to use this function
However, sugestions from Ivar and knowledge base 913 was helpful.
-Thanks
Kumar
The special operator "timeint()" is in v4.2a (1.66 is my current one) try a help search "timeint" or "special operators"
It's limited to post processing though. For the solver process you must go via the ODE as described in the KB
Suggested Content
- BLOG Overview of Integration Methods in Space and Time
- FORUM Implementing integral across time using analytic temperature-based function
- KNOWLEDGE BASE Solving Wave-Type Problems with Step Changes in the Loads
- FORUM Defining a function as definite integral
- BLOG How to Identify and Resolve Singularities in the Model when Meshing
