boundary load F(x,y)
i´m struggling with a simple question... How can I set up a boundary load in z-direction like F(x,y) in solid mechanics?!
Thanks!
2 Replies Last Post 2010/10/29 8:14 GMT-4
Posted: 2 decades ago 2010/10/29 5:21 GMT-4
type in your equation in the load BC with the x,y variables.
Example:
cylinder of radius R: axis along z, fixed at the lower end surface
on the upper edge rim you apply a Moment M0 [N*m] defined as an edge load force in global coordinates:
Fx = -y*M0/R
Fy = +x*M0/R
see the 3.5a moment load example in structural doc
Hi type in your equation in the load BC with the x,y variables. Example: cylinder of radius R: axis along z, fixed at the lower end surface on the upper edge rim you apply a Moment M0 [N*m] defined as an edge load force in global coordinates: Fx = -y*M0/R Fy = +x*M0/R see the 3.5a moment load example in structural doc -- Good luck Ivar
Posted: 2 decades ago 2010/10/29 8:14 GMT-4
Thanks Ivar!
Sometimes the solution is much easier as it seem to be :-)
Thanks Ivar! Sometimes the solution is much easier as it seem to be :-)
