point on interface (two phase flow level set)
I would like to know if the following problem has a solution.
In the "Two phase flow level set module " of comsol, I am simulating an air bubble (3D) in water domain. Depending on the pressure in the water domain, the radius of the air bubble should change. I simulated the same in the module. now, I want to find the radius of the bubble at all time steps. One way is to find the two points on the interface where x and y coordinates are zero and the average of the z coordinates give the radius.
Is there any way to find the points on the interface in this module? Or is there any other way to get around this problem?
Any help would be much appreciated.
Hari
0 Replies Last Post 2016/04/04 21:19 JST
Hello Hari Krishnan
