overall conductivity of the system
Hi, experts!
I am novice and want to ask: Is it possible to calculate overall conductivity of the composite containing high conductive nanoparticles in almost non-conductive media?
If yes, which modules and functions should I use? Probably there are some nearest examples.
Thanks in advance, I will be grateful for any advice and help
2 Replies Last Post 2016/04/13 1:40 GMT-4
Posted: 10 years ago 2016/04/13 1:23 GMT-4
I am not sure if this is a Comsol problem at all. A situation like yours is usually analyzed with the percolation theory. The conductivity is zero before the nanoparticles create a continuous path across the sample. There are Matlab codes available in the web that calculate this.
BR
Lasse
Hi I am not sure if this is a Comsol problem at all. A situation like yours is usually analyzed with the percolation theory. The conductivity is zero before the nanoparticles create a continuous path across the sample. There are Matlab codes available in the web that calculate this. BR Lasse
Posted: 10 years ago 2016/04/13 1:40 GMT-4
You may set a potential difference across the sample and integrate current in either ends. Then Ohm's law. You may also scan the potential difference with parametric sweep.
