Jeff Hiller
COMSOL Employee
9 years ago
2016/06/15 2:42 JST
Hello August,
In principle, what you are doing will work if you implement it correctly (assuming that your equations are only one-way coupled; if they are two-way coupled you need to use a single study). Consider posting a more detailed description of what you want your model to do (equations, BCs, geometry, etc) as well as your mph file if you'd like Discussion Forum users to look at how you tried to set it up.
Hello August,
9 years ago
2016/06/15 3:03 JST
okay thanks for the answer. The equations are two way coupled and what I do is perform a parametric sweep over the first equation, where I sweep over K*u2, where K=0 at first and then I sweep up to K=1. Here u2 is the solution to the second equation, in which the solution u also enters. So to summarize.
I solve the first PDE for K=0, plug this solution into the second PDE. I then solve this for u2 and put in K*u2, where K is now non-zero (defined by the sweep).
Then I reiterate this process.
I have attached my .mph file. It is written in COMSOL 5.1. I hope that will work for you.
