How to input the square of a differential?
comsol version 4.0 or higher
How to express (?u)^2, ? represents differential here, u is a dependent variable, u(x, y)
Is this right: (ux+uy)^2 ?
3 Replies Last Post 2011/01/19 1:48 GMT-5
Posted: 1 decade ago 2011/01/18 14:40 GMT-5
I do not believe so, if your vector field "_u_(x,y,z)" (_in bold_) is in fact the vector field of scalar values (u,v,w) for 3D then what do you really mean by du ?
In COMSOL notation
(ux+uy)^2 = (du/dx+dudy)^2
I agree I find too that using "u" for the general vector field and for the 1st part of the vector is confusing, normally they were using bold case for the full vector field and normal case for u,v,w. tehn if you look up the doc, you will see that ux=du/dx, uy=du/dy vx=dv/dx and wt=dw/dt, just as uxx=d^2u/dx^2 vxy=d^2u/dx/dy
This means als that one need to take some precautions when inventing variable names with COMSOL and not to redefine internal ones, the results might be strange ;)
Hi I do not believe so, if your vector field "_u_(x,y,z)" (_in bold_) is in fact the vector field of scalar values (u,v,w) for 3D then what do you really mean by du ? In COMSOL notation (ux+uy)^2 = (du/dx+dudy)^2 I agree I find too that using "u" for the general vector field and for the 1st part of the vector is confusing, normally they were using bold case for the full vector field and normal case for u,v,w. tehn if you look up the doc, you will see that ux=du/dx, uy=du/dy vx=dv/dx and wt=dw/dt, just as uxx=d^2u/dx^2 vxy=d^2u/dx/dy This means als that one need to take some precautions when inventing variable names with COMSOL and not to redefine internal ones, the results might be strange ;) -- Good luck Ivar
Posted: 1 decade ago 2011/01/18 21:50 GMT-5
In COMSOL notation
Sorry, maybe I didn't say what I want to say clearly.
the "?" refer to the vector differential operator (gradient), ?u=(ux, uy) or ?u=(du/dx, du/dy)
and I want to know how to express (?u)^2 in comsol.
(?u)^2=(ux)^2+(uy)^2, or (?u)^2=(ux+uy)^2, which is right in comsol?
[QUOTE] Hi I do not believe so, if your vector field "_u_(x,y,z)" (_in bold_) is in fact the vector field of scalar values (u,v,w) for 3D then what do you really mean by du ? In COMSOL notation (ux+uy)^2 = (du/dx+dudy)^2 I agree I find too that using "u" for the general vector field and for the 1st part of the vector is confusing, normally they were using bold case for the full vector field and normal case for u,v,w. tehn if you look up the doc, you will see that ux=du/dx, uy=du/dy vx=dv/dx and wt=dw/dt, just as uxx=d^2u/dx^2 vxy=d^2u/dx/dy This means als that one need to take some precautions when inventing variable names with COMSOL and not to redefine internal ones, the results might be strange ;) -- Good luck Ivar [/QUOTE] Sorry, maybe I didn't say what I want to say clearly. the "?" refer to the vector differential operator (gradient), ?u=(ux, uy) or ?u=(du/dx, du/dy) and I want to know how to express (?u)^2 in comsol. (?u)^2=(ux)^2+(uy)^2, or (?u)^2=(ux+uy)^2, which is right in comsol?
Posted: 1 decade ago 2011/01/19 1:48 GMT-5
for me that is pure maths, no ?
the norm of a gradient is the sum of squares of the components (and not the square of a sum)
or have I missed something ?
Hi for me that is pure maths, no ? the norm of a gradient is the sum of squares of the components (and not the square of a sum) or have I missed something ? -- Good luck Ivar
