Boundary heat source with temperature as a dependent variable
I'm try to solve this solid heat transfer case with a boundary heat source. The heat source Q is a function of surface temperature. Can I just use 'boundary heat source' boundary condition with the Qb=f(T) equation?
Will this result in non-linearity because of solution dependency? If so, what is the right way to do it?
Thank you very much.
2 Replies Last Post 2017/04/02 15:09 GMT-4
Posted: 9 years ago 2017/04/02 11:39 GMT-4
Fei
It should not be a problem. I have used this method to impose a boundary heat sink at an evaporating interface (Qb=f(T)) and it gave me a good result which matched the temperatures that I'd measured by a thermocouple in the Lab. Keep in mind that you must set a good initial value for the temperature since it uses the initial temperature to start calculating Qb.
My suggestion is that you design a 1D model for which you already know the analytical solution (Somthing like heat transfer through a wall with convective heat transfer at one side and known temperature at the other side). Then solve it numerically with Comsol and compare the results.
Amin,
Fei It should not be a problem. I have used this method to impose a boundary heat sink at an evaporating interface (Qb=f(T)) and it gave me a good result which matched the temperatures that I'd measured by a thermocouple in the Lab. Keep in mind that you must set a good initial value for the temperature since it uses the initial temperature to start calculating Qb. My suggestion is that you design a 1D model for which you already know the analytical solution (Somthing like heat transfer through a wall with convective heat transfer at one side and known temperature at the other side). Then solve it numerically with Comsol and compare the results. Amin,
Posted: 9 years ago 2017/04/02 15:09 GMT-4
Amin,
Thank you so much!
Fei
Amin, Thank you so much! Fei
