Using previous solution as initial values
Posted 2017/04/10 8:55 GMT-4 Mesh, Results & Visualization, Studies & Solvers, Structural Mechanics Version 5.1, Version 5.2, Version 5.2a 3 Replies
Dear all,
I am trying to get familiar with how to use results from a previous solution as initial conditions in a new solution. To do this I am using a very simple model (see description down below) but I seem to be unable to get it to work.
In the first part of my model I am using a solid mechanics physics where I have a simple square with roller boundary conditions on the right and lower boundaries. The top boundary has a prescribed displacement that depends linearly on time.
After this I use the "Remesh deformed configuration". I then import this mesh as the geometry for my second physics node, which is also solid mechanics. The new geometry is the same as the solution from the first study, so far so good. I use the same roller boundaries but this time I prescribe a time dependent displacement on the left boundary. In this study I set the "Initial values of variables solved for" to User controlled - Solution - Study 1 - Last. However, the stress at time zero is still much lower that the last time step in Study 1.
I would be very greatful for any help on what I might do wrong or if I can do this another way.
Kind regards,
Lisa
Kind regards,
Lisa
3 Replies Last Post 2017/04/11 4:07 GMT-4
