problem in implementing laminar inflow as BCs in 5.2
Posted 2017/08/26 22:47 JST Fluid & Heat Version 5.2 1 Reply
Hello friends,
I have built a microfluidic model in COMSOL 5.2. It's a basically 2D long pipe. I tried to use 'laminar inflow -> flow rate' and 'laminar outflow -> pressure' as inlet and outlet BCs respectively. But the software failed to give an answer. Instead, if I specified pressure at both boundaries, then it succeeded to give a result. So how can I use the 'flow rate' as an inlet BC properly?
1 Reply Last Post 2017/08/30 19:49 JST
