Frequency Analysis for structure with Film Damping
Hi All,
I want to do frequency response analysis for a structure with film damping. Is there any existing model in comsol for that or has anybody done somethin on this? Please let me know if you have any information.
Siddhartha
4 Replies Last Post 2011/11/03 0:32 JST
Posted: 1 decade ago 2011/03/30 4:20 JST
have you checked the model builder in the mems section, there is a film damping example, cannot remember if it was frequency sweep (believe so) or only eigenfrequency analysis
Hi have you checked the model builder in the mems section, there is a film damping example, cannot remember if it was frequency sweep (believe so) or only eigenfrequency analysis -- Good luck Ivar
Posted: 1 decade ago 2011/04/01 14:32 JST
Hi Ivar,
I have found one example on squeeze film, but it is on a transient problem.
Siddhartha
Hi Ivar, I have found one example on squeeze film, but it is on a transient problem. Siddhartha
Posted: 1 decade ago 2011/04/03 19:02 JST
I want to find out frequency response of a squeeze film with structure. Can anybody help me with existing module or instructions?
Siddhartha
Hi, I want to find out frequency response of a squeeze film with structure. Can anybody help me with existing module or instructions? Thanks, Siddhartha
Posted: 1 decade ago 2011/11/03 0:32 JST
Hi Siddhartha,
Did you find a solution?
I also want to do squeeze-film damping frequency response. Mostly I just want to model the quality factor.
The other problem is, I have an arbitrary geometry. The model in the Comsol Model Library uses the math to assume the air is squeezed out only at the edges -- if you add periodic holes then you have to use different math to assume that the air is squeezed out the holes. (So you can see what I mean, go here: www.comsol.com/multiphysics/slidingfilms/, download the pdf for the model, and look on Page 2 where it references Ref 3).
However Ref 3 only includes periodic holes. I have a funny arbitrary geometry...
Any ideas?
Hi Siddhartha, Did you find a solution? I also want to do squeeze-film damping frequency response. Mostly I just want to model the quality factor. The other problem is, I have an arbitrary geometry. The model in the Comsol Model Library uses the math to assume the air is squeezed out only at the edges -- if you add periodic holes then you have to use different math to assume that the air is squeezed out the holes. (So you can see what I mean, go here: http://www.comsol.com/multiphysics/slidingfilms/, download the pdf for the model, and look on Page 2 where it references Ref 3). However Ref 3 only includes periodic holes. I have a funny arbitrary geometry... Any ideas? Thanks
