Discussion Locked This discussion was locked by a forum moderator.
RF module Mie scattering tutorial (gold sphere)
www.comsol.com/showroom/gallery/3459/
I obtained the absorption cross-section and scattering cross-section,but i want to obtain
absorption coefficient and scattering coefficient ? what to do next?
thanks a lot
9 Replies Last Post 2017/02/13 23:11 JST
Hello WB Zou
Posted: 1 decade ago 2011/07/29 20:11 JST
hi WB,
i am having trouble in calculating scattering cross secrion and absorbstion cross section in comsol 4.2 ,which is basically re-writing - mie scattering from sphere 3.5a in version to 4.2. Can u help me figure out the error.
hi WB, i am having trouble in calculating scattering cross secrion and absorbstion cross section in comsol 4.2 ,which is basically re-writing - mie scattering from sphere 3.5a in version to 4.2. Can u help me figure out the error.
Posted: 1 decade ago 2011/08/25 16:31 JST
Hi, Anupam Ghosh
I downloaded your mph file. However, it cannot be performed in our workstation.
I guess it is the problem that several variables should be changed to ones which can be recognized by COMSOL 4.2.
In fact, I can not find variables like "scEx, scEy" etc in COMSOL 4.2
Have you solved the problem?
hi WB,
Hi, Anupam Ghosh I downloaded your mph file. However, it cannot be performed in our workstation. I guess it is the problem that several variables should be changed to ones which can be recognized by COMSOL 4.2. In fact, I can not find variables like "scEx, scEy" etc in COMSOL 4.2 Have you solved the problem? [QUOTE] hi WB, i am having trouble in calculating scattering cross secrion and absorbstion cross section in comsol 4.2 ,which is basically re-writing - mie scattering from sphere 3.5a in version to 4.2. Can u help me figure out the error. [/QUOTE]
Posted: 1 decade ago 2011/08/25 16:32 JST
Hi, WB.
I am now using v4.2. Have you ever got the ACS and SCS in v4.2?
We have problems realizing the model in v4.2.
thanks a lot
Hi, WB. I am now using v4.2. Have you ever got the ACS and SCS in v4.2? We have problems realizing the model in v4.2. [QUOTE] http://www.comsol.com/showroom/gallery/3459/ I obtained the absorption cross-section and scattering cross-section,but i want to obtain absorption coefficient and scattering coefficient ? what to do next? thanks a lot [/QUOTE]
Posted: 1 decade ago 2011/08/25 17:43 JST
Hi keya,
Thanks for trying to trouble shoot the problem.
Yes u r correct - its the variable mismatch that's causing the problem .
For info about variable names in Comsol 4.2 ,try the equation view mode (in model builder tab --> an eye is made -->click n choose equation view) and then see various categories under the physics --> electromagnetic waves.
I have still not figured out the way to run 3.5a Mie scattering in 4.2 but the method i m adopting is :-
i m running the 3.5a program in 3.5a and then i ll compare (check out - "equation system view" in 3.5a, u can find more about it in help files of 3.5a + Far-Field post processing in 3.5a) with the settings in 4.2 ,may be that can give a clue about modifications to b made in 3.5a version so as to run it in 4.2.
keep me updated with yr progress...
Hi keya, Thanks for trying to trouble shoot the problem. Yes u r correct - its the variable mismatch that's causing the problem . For info about variable names in Comsol 4.2 ,try the equation view mode (in model builder tab --> an eye is made -->click n choose equation view) and then see various categories under the physics --> electromagnetic waves. I have still not figured out the way to run 3.5a Mie scattering in 4.2 but the method i m adopting is :- i m running the 3.5a program in 3.5a and then i ll compare (check out - "equation system view" in 3.5a, u can find more about it in help files of 3.5a + Far-Field post processing in 3.5a) with the settings in 4.2 ,may be that can give a clue about modifications to b made in 3.5a version so as to run it in 4.2. keep me updated with yr progress...
Posted: 1 decade ago 2011/08/25 17:56 JST
I already tried the equation view mode. However, I cannot find the scattered electromagnetic field corresponding to scEx, or scHy etc.
BTW, it seems that the parameters and variables are both changed in COMSOL v4.2. I guess it might be the reason why we cannot perform the simulation in 4.2.
I am now studying on that.
"www.comsol.com/community/forums/general/thread/18827/" also gave some comments on this issue which might help.
Hi keya,
I already tried the equation view mode. However, I cannot find the scattered electromagnetic field corresponding to scEx, or scHy etc. BTW, it seems that the parameters and variables are both changed in COMSOL v4.2. I guess it might be the reason why we cannot perform the simulation in 4.2. I am now studying on that. "http://www.comsol.com/community/forums/general/thread/18827/" also gave some comments on this issue which might help. [QUOTE] Hi keya, Thanks for trying to trouble shoot the problem. Yes u r correct - its the variable mismatch that's causing the problem . For info about variable names in Comsol 4.2 ,try the equation view mode (in model builder tab --> an eye is made -->click n choose equation view) and then see various categories under the physics --> electromagnetic waves. I have still not figured out the way to run 3.5a Mie scattering in 4.2 but the method i m adopting is :- i m running the 3.5a program in 3.5a and then i ll compare (check out - "equation system view" in 3.5a, u can find more about it in help files of 3.5a + Far-Field post processing in 3.5a) with the settings in 4.2 ,may be that can give a clue about modifications to b made in 3.5a version so as to run it in 4.2. keep me updated with yr progress... [/QUOTE]
Posted: 1 decade ago 2011/08/25 18:13 JST
Yes , i have see that thread .rfw vs .emw
i think the way the same algorithm of 3.5a will b executed in 4.2 will b different (even after fixing the variable issue).
now since we know the problem, lets see if we can come up with the solution.
best...
Yes , i have see that thread .rfw vs .emw i think the way the same algorithm of 3.5a will b executed in 4.2 will b different (even after fixing the variable issue). now since we know the problem, lets see if we can come up with the solution. best...
Posted: 1 decade ago 2011/10/05 3:01 JST
Hi guys,
I just saw this thread. I am also having the same problem in calculating the far field properties of a nanosphere in v4.2. Did you guys figure out the problem if yes then please guide me also.
BR,
Adnan
Hi guys, I just saw this thread. I am also having the same problem in calculating the far field properties of a nanosphere in v4.2. Did you guys figure out the problem if yes then please guide me also. Thanks, BR, Adnan
Posted: 8 years ago 2017/02/12 5:21 JST
any one have find scartering and absorptin cross section then sendme please...
Walter Frei COMSOL Employee
Posted: 8 years ago 2017/02/13 23:11 JST
The discussion in this thread originates with a model that is out-of-date and no longer available on our website. That model addressed the question of modeling scattering off of a gold nanoshpere, and there is a newer model that should address all of the questions raised here:
www.comsol.com/model/optical-scattering-by-gold-nanospheres-14697
Since this thread does discuss questions relating to an out-of-date model, we are going to close this thread for further comments. If there are questions about the above model, please of course feel free to open a new discussion thread.
Best Regards,
Hello, The discussion in this thread originates with a model that is out-of-date and no longer available on our website. That model addressed the question of modeling scattering off of a gold nanoshpere, and there is a newer model that should address all of the questions raised here: https://www.comsol.com/model/optical-scattering-by-gold-nanospheres-14697 Since this thread does discuss questions relating to an out-of-date model, we are going to close this thread for further comments. If there are questions about the above model, please of course feel free to open a new discussion thread. Best Regards,
