Insert values from external file or defined variable to set initial guess value in parametric solvers
Posted 2018/03/28 10:57 GMT-4 Modeling Tools & Definitions, Optimization, Parameters, Variables, & Functions Version 5.2a 0 Replies
Hi, Is there a way to insert the initial guess values for the different runs of a parametric solver through an external data file or a column vector? The guess values need to be quite far away from the solution of the previous result, so the parametric solver is having trouble finding the relevant solutions using the previous solution as the initial guess value. Any advice/suggestiob would be much appreciated.
Regards
Hello Sonali Dasgupta
