Assigning new material with non linear B-H and H-B relations
Hello sir, I am working on Magnetorheological fulid applications. I want to do Multi physics study for my product, so i am using Comsol for the simulations. The magnetic properties of this materials are non linear. i have excel data for B-H and H-B curves. But i dont know how to assign this data in comsol. so please help me with some example or procedure. Thanking you.
3 Replies Last Post 2018/08/30 21:21 JST
Mickaël Barsive COMSOL Employee
Posted: 7 years ago 2018/08/28 21:44 JST
Updated: 7 years ago 2018/08/28 21:58 JST
I could advice you to have a look on a tutorial model using BH curve such as the "Ecore Transformer": https://www.comsol.fr/model/e-core-transformer-14123
Under the node "Soft Iron (without losses)" in "Material" you will find how a BH curve is defined in COMSOL Multiphysics using "Interpolation" function.
In your case, you could use the "From file" option in "Interpolation" to import your data from a csv file.
I hope this helps.
Please contact the COMSOL technical support for more details.
Mickaël
Hello, I could advice you to have a look on a tutorial model using BH curve such as the "Ecore Transformer": https://www.comsol.fr/model/e-core-transformer-14123 Under the node "Soft Iron (without losses)" in "Material" you will find how a BH curve is defined in COMSOL Multiphysics using "Interpolation" function. In your case, you could use the "From file" option in "Interpolation" to import your data from a csv file. I hope this helps. Please contact the COMSOL technical support for more details. Mickaël
Posted: 7 years ago 2018/08/30 18:13 JST
Updated: 7 years ago 2018/08/30 21:15 JST
Hello sir, i tried to do the same. but i am getting error 'Failed to find a solution''Singular matrix'' '. here i am attaching the following files. 1. with normal soft iron for (domain-2) 2. HB,BH values changed file 3. BH data. please look in to it and give the solution. Thanking you
Posted: 7 years ago 2018/08/30 21:21 JST
Updated: 7 years ago 2018/08/30 21:28 JST
For this kind of question, please contact the COMSOL technical support.
Usually in "Magnetic field (mf)" interface you can meet this error in time or frequency domain when the electrical conductivity of air is stricly null (try with 0.1[S/m] for example).
Mickaël
Hello, For this kind of question, please contact the COMSOL technical support. Usually in "Magnetic field (mf)" interface you can meet this error in time or frequency domain when the electrical conductivity of air is stricly null (try with 0.1[S/m] for example). Regards, Mickaël
