How to use the result of each time-step as input to next time-step?
Basically this is how I would do it in hand calculation:
T_out_0 = 22 [degC] %% Guessed initial value.
%% at t=1:
COP(1) = 5[1/K] * T_out_0
T_out(1) = T_avg_Domain(1) - COP(1)/7[1/K]
%% at t=2:
COP(2) = 5[1/K] * T_out(1)
T_out(2) = T_avg_Domain(2) - COP(2)/7[1/K]
and so on ..
My problem is how to calculate COP from the previous T_out? When I define this in Variables node (As shown below), I got this warning: "circular variable dependencies".
COP : 5[1/K] * T_out
T_out : T_avg_Domain - COP/7[1/K]
1 Reply Last Post 2019/05/22 21:33 JST
Michael Rembe Certified Consultant
Posted: 6 years ago 2019/05/22 21:33 JST
Hi, you have to define an aditional variable Tav_old (add physics -> Global ODEs and DAEs). Add the equation 0=Tav_old-T_avg_Domain (variable: Tav_old, equation: Tav_old-T_avg_Domain. Then you add a "Previous Solution" subnode below the time dependent solver and solve for Tav_old. By this way you get Tav_old of the old solution.
Best regards Michael Rembe
Michael Rembe
Rembe Consulting PartG mbB
www.rembe-consulting.de
Hi, you have to define an aditional variable Tav_old (add physics -> Global ODEs and DAEs). Add the equation 0=Tav_old-T_avg_Domain (variable: Tav_old, equation: Tav_old-T_avg_Domain. Then you add a "Previous Solution" subnode below the time dependent solver and solve for Tav_old. By this way you get Tav_old of the old solution. Best regards Michael Rembe
