results from frequency response is not matching the eigen v
Hello everyone,
I am modeling a structural mechanics with ale mesh frame and electrostatic in this frame.. in an axi-symmetric 2d model (MEMS module)..
The problem is ... When I solve for the eigenvalues I got a resonance at 1MHz and then at 4.1MHz and the third at 9MHz
but when I solve for the frequency response analysis I found different result
thanks you so much for your support
yours
Mark George
6 Replies Last Post 2012/02/12 20:32 JST
Posted: 1 decade ago 2012/02/11 20:31 JST
kindly find design attached
Posted: 1 decade ago 2012/02/11 20:32 JST
if you are in v4.2 or 4.2a you should be aware of the importance od the order in which you apply the multiple physics, either you use the coupled (pre-cooked) EMI physics, or you should use the ALE + Solid+ EC/ES physcs, but then be sure you START with the ALE before the solid, as both use the spatial frame, and if you arrange them the other way you will have some surprises with the result. COMSOL has told me they will issue a warning, or automatically arrange the order in the next release, but currently with 4.2 one must take care manually
Hi if you are in v4.2 or 4.2a you should be aware of the importance od the order in which you apply the multiple physics, either you use the coupled (pre-cooked) EMI physics, or you should use the ALE + Solid+ EC/ES physcs, but then be sure you START with the ALE before the solid, as both use the spatial frame, and if you arrange them the other way you will have some surprises with the result. COMSOL has told me they will issue a warning, or automatically arrange the order in the next release, but currently with 4.2 one must take care manually -- Good luck Ivar
Posted: 1 decade ago 2012/02/11 20:39 JST
Thanks for yours reply
but I use COMSOL 3.4 not the new version
Mark George
Thanks for yours reply but I use COMSOL 3.4 not the new version Mark George
Posted: 1 decade ago 2012/02/11 21:29 JST
The same problem occurs .. the output frequency response couldn't be right at all
:S
The same problem occurs .. the output frequency response couldn't be right at all :S
Posted: 1 decade ago 2012/02/12 17:34 JST
Thank you Ivar for your answer
But Is it important in all the analysis ( parametric and eigenvalues ) or in the frequency response analysis only ?
As when I run the parametric analysis and the eigenvalues I got results near the predicted results
but when I run the frequency response analysis I got a very far results from the predicted
So where is the problem ?????
yours
Mark George
Thank you Ivar for your answer But Is it important in all the analysis ( parametric and eigenvalues ) or in the frequency response analysis only ? As when I run the parametric analysis and the eigenvalues I got results near the predicted results but when I run the frequency response analysis I got a very far results from the predicted So where is the problem ????? yours Mark George
Posted: 1 decade ago 2012/02/12 20:32 JST
not sure why, as I do not have any older version (only the latest 4.2a) running I cannot test anything out, from my remindings, frequency scans and eigenmodes agreed,
I usually run an eigenfrequency first to define the modes, and then use those to define the stepping (manually with many points around the eigenfrequencies). If you leave the system free it will most proably skip all narrow peaks.
Adding some damping often helps the convergence too
Hi not sure why, as I do not have any older version (only the latest 4.2a) running I cannot test anything out, from my remindings, frequency scans and eigenmodes agreed, I usually run an eigenfrequency first to define the modes, and then use those to define the stepping (manually with many points around the eigenfrequencies). If you leave the system free it will most proably skip all narrow peaks. Adding some damping often helps the convergence too -- Good luck Ivar
