How to use the temperature of one study into another study. correct method or not?
Dear all, I tried to couple the temperature of study1 into Study2 (study1 is heating, Study2 is cooling) it can not be done in 1 study because in study 2 we have also air cooling, and the time of study1 is unknown.
I first tried some simple things and it worked, can you specialists have a look to the method is it principally correct (physics not important in this topic)?
Step 1: make a global variable
Expression: mod1.T
This will store all the temperatures on all places from study1 but on which times?
Step 2: calculate study 1
Step 3: add physics: (heat transfer in solids 2 (ht2))
Add study (un check the ht1 mode in the physics selection)
Step 4: Initial values in ht2
T2= Starttemp
Step 5: Dependent variables
General:
Defined study step: user defined
Initial values of variables solved for:
Method: Initial expression
Solution: Solver 1
Time: Automatic or last time step
Scaling
Method: Automatic
Values of variables not solved for
Method: Solution
Solution: Solver 1
Output
Keep solution: initial values
Step6: Run study 2
Step 7: take care by looking to the results: the temperature of study 2 is T2 not T
3 Replies Last Post 2012/03/28 22:45 JST
Posted: 1 decade ago 2012/03/28 19:00 JST
the principal model is in attachment without solutions
Lechoslaw Krolikowski
Posted: 1 decade ago 2012/03/28 19:59 JST
For correct method see thread 16346 in this forum.
Andrzej
Hi, For correct method see thread 16346 in this forum. Best regards, Andrzej
Posted: 1 decade ago 2012/03/28 22:45 JST
www.comsol.dk/community/forums/general/thread/16346/
it is giving the same results.
But in the method mentioned in the link, you need to manually change the physics?
You can not choose heat transfer in solids and conjugated heat transfer in the solver?
This last point is intersting for me because then I don't need to change my model because of having different physics in the different studies?
Also I'm dealing some problems with finding back the boundary probes results from the first solver (it is always giving the results of the second solver (I used also different time steps to evaluate but also second time steps were taken)
http://www.comsol.dk/community/forums/general/thread/16346/ it is giving the same results. But in the method mentioned in the link, you need to manually change the physics? You can not choose heat transfer in solids and conjugated heat transfer in the solver? This last point is intersting for me because then I don't need to change my model because of having different physics in the different studies? Also I'm dealing some problems with finding back the boundary probes results from the first solver (it is always giving the results of the second solver (I used also different time steps to evaluate but also second time steps were taken)
