Meshing Using Geometry Difference Feature
I'm doing a project for an aerospace class in which I'm completing a fluid-structure analysis of a balloon design. In order to generate the balloon structure and interior helium I used a difference in geometry (See the attached COMSOL model). When I go to mesh the model setup I recieve an error that domain 2, the balloon domain, doesn't mesh properly. I figure there may be an issue with the geometry difference feature. Can anyone provide any insight on my issue? I wish to generate a mesh of the entire model ASAP.
Thank you in advance!
3 Replies Last Post 2012/04/16 23:28 JST
Posted: 1 decade ago 2012/04/16 15:46 JST
you issue is that you have a far too coarse mesh, and your very thin entity (Domain 2) needs to be defined with a "extremely fine" mesh Size (or even finer = manual settings)
Furthermore, I'm not sure your material is really well represented by "Linear Elastic" but why not start with that
Hi you issue is that you have a far too coarse mesh, and your very thin entity (Domain 2) needs to be defined with a "extremely fine" mesh Size (or even finer = manual settings) Furthermore, I'm not sure your material is really well represented by "Linear Elastic" but why not start with that -- Good luck Ivar
Posted: 1 decade ago 2012/04/16 18:41 JST
Thank you for your help. I will try meshing it again with your suggestions. Also, I changed the linear-elastic model to hyperelastic. Maybe that will descirbe the deformation of the balloon better.
Posted: 1 decade ago 2012/04/16 23:28 JST
Try to predifine the mesh of cube = Normal and Edge=extremely fine
You will get the response
Dinh An
Hi, Try to predifine the mesh of cube = Normal and Edge=extremely fine You will get the response Dinh An
