How to Plot Distance
Walter Frei published a blog "How to Compute Distances Between Objects in COMSOL Multiphysics" (https://www.comsol.com/blogs/how-to-compute-distances-between-objects-in-comsol-multiphysics/) which is great but completely passes over the question of how do I generate the plots that he shows. The only place I can see to make plots is down in the results section and it won't do anything without a dataset and, of course, I don't have one because all I have is some geometry and some functions. I have been unable to find the part in the manual that describes how this can be done. Can someone please point me int he right direction
1 Reply Last Post 2022/03/28 7:02 GMT-4
Posted: 3 years ago 2022/03/28 7:02 GMT-4
Updated: 3 years ago 2022/03/28 7:50 GMT-4
The probably fastest way to generate a dataset, so that you can create plots, is to add an Empty Study, and then click on Get Initial Values.
Henrik Sönnerlind
COMSOL
The probably fastest way to generate a dataset, so that you can create plots, is to add an *Empty Study*, and then click on *Get Initial Values*.
