Equation for calculating values?
After the calculation with the solid and fluid heat transfer module, the values of internal energy and total internal energy can be derived directly, that is, ht Ei and ht Ei0. What is the difference between the two values? Or is there any equation to refer to?
5 Replies Last Post 2022/05/13 4:48 JST
Posted: 3 years ago 2022/05/12 1:11 JST
ht.Ei - ht.Ei0
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
ht.Ei - ht.Ei0
Jeff Hiller COMSOL Employee
Posted: 3 years ago 2022/05/12 2:42 JST
Updated: 3 years ago 2022/05/12 3:10 JST
You can find the mathematical definitions for all quantities in your model by turning on Equation View (You can activate it by clicking the "Show More Options" icon, which looks like an eye and is located at the top of the Model Builder window) and then using Ctrl+R. See this other thread for a bit more detail.
Jeff Hiller
You can find the mathematical definitions for all quantities in your model by turning on Equation View (You can activate it by clicking the "Show More Options" icon, which looks like an eye and is located at the top of the Model Builder window) and then using Ctrl+R. See [this other thread](https://www.comsol.com/forum/thread/45363/variable-names-in-equation-view?last=2022-04-28T15:29:32Z) for a bit more detail. Jeff
Posted: 3 years ago 2022/05/12 15:49 JST
ht.Ei - ht.Ei0
I do not understand
>ht.Ei - ht.Ei0 I do not understand
Posted: 3 years ago 2022/05/12 16:26 JST
Updated: 3 years ago 2022/05/13 4:51 JST
You can find the mathematical definitions for all quantities in your model by turning on Equation View (You can activate it by clicking the "Show More Options" icon, which looks like an eye and is located at the top of the Model Builder window) and then using Ctrl+F. See this other thread for a bit more detail.
Thanks!
>You can find the mathematical definitions for all quantities in your model by turning on Equation View (You can activate it by clicking the "Show More Options" icon, which looks like an eye and is located at the top of the Model Builder window) and then using Ctrl+F. See [this other thread](https://www.comsol.com/forum/thread/45363/variable-names-in-equation-view?last=2022-04-28T15:29:32Z) for a bit more detail. > >Jeff Thanks!
Posted: 3 years ago 2022/05/13 4:48 JST
ht.Ei - ht.Ei0
I do not understand
This is the expression you can use to evaluate and/or plot the difference of the two quantities
Edgar J. Kaiser
www.emphys.com
>>ht.Ei - ht.Ei0 > >I do not understand This is the expression you can use to evaluate and/or plot the difference of the two quantities
