does heat transfer in solids and fluids include convection?
Hello everyone,
I want to know if the physics "heat transfer in solids and fluids" alone includes natural convection or if I need to add Laminar flow with it.
Sincerely,
7 Replies Last Post 2023/06/19 12:26 GMT-4
Posted: 11 months ago 2023/06/14 1:00 GMT-4
you should use a fluid interface to consider the 'convection'.
Posted: 11 months ago 2023/06/14 4:42 GMT-4
Ok, thanks for your reply
Magnus Ringh COMSOL Employee
Posted: 11 months ago 2023/06/14 8:12 GMT-4
Updated: 11 months ago 2023/06/15 2:18 GMT-4
To clarify: The Heat Transfer in Solids and Fluids physics interface includes both a Solid node for heat conduction in solid domains and a Fluid node for heat convection and conduction in fluid domains, so you can use it for heat convection, but a Heat Transfer in Fluids physics interface is more appropriate if the entire computational domain consists of fluids. For the heat convection, the velocity can be taken from an added fluid-flow interface in your model, or you can use a user-defined expression for the velocity field. There is also a predefined Conjugate Heat Transfer multiphysics interface, which includes a laminar or turbulent fluid-flow interface and a predefined multiphysics coupling between the heat transfer and the fluid flow for modeling nonisothermal flow.
Magnus
Hi, To clarify: The Heat Transfer in Solids and Fluids physics interface includes both a Solid node for heat conduction in solid domains and a Fluid node for heat convection and conduction in fluid domains, so you can use it for heat convection, but a Heat Transfer in Fluids physics interface is more appropriate if the entire computational domain consists of fluids. For the heat convection, the velocity can be taken from an added fluid-flow interface in your model, or you can use a user-defined expression for the velocity field. There is also a predefined Conjugate Heat Transfer multiphysics interface, which includes a laminar or turbulent fluid-flow interface and a predefined multiphysics coupling between the heat transfer and the fluid flow for modeling nonisothermal flow. Best regards, Magnus
Posted: 11 months ago 2023/06/15 11:00 GMT-4
Magnus
Hi, Thanks for your reply now I understand it better. I have a question, when I use Conjugate Heat Transfer, does it also take in consideration heat transfer by radiation?
Best regards, Mohammed
>Hi, > >To clarify: The Heat Transfer in Solids and Fluids physics interface includes both a Solid node for heat conduction in solid domains and a Fluid node for heat convection and conduction in fluid domains, so you can use it for heat convection, but a Heat Transfer in Fluids physics interface is more appropriate if the entire computational domain consists of fluids. For the heat convection, the velocity can be taken from an added fluid-flow interface in your model, or you can use a user-defined expression for the velocity field. There is also a predefined Conjugate Heat Transfer multiphysics interface, which includes a laminar or turbulent fluid-flow interface and a predefined multiphysics coupling between the heat transfer and the fluid flow for modeling nonisothermal flow. > >Best regards, > >Magnus Hi, Thanks for your reply now I understand it better. I have a question, when I use Conjugate Heat Transfer, does it also take in consideration heat transfer by radiation? Best regards, Mohammed
Posted: 11 months ago 2023/06/16 2:28 GMT-4
Updated: 11 months ago 2023/06/16 2:29 GMT-4
Hi Mohammed,
With the Conjugate Heat Transfer multiphysics interface, you can add surface-to-ambient radiation to boundaries. With the Heat Transfer Module, there are additional physics interfaces for surface-to-surface radiation that you can add to the model if needed.
Magnus
Hi Mohammed, With the Conjugate Heat Transfer multiphysics interface, you can add surface-to-ambient radiation to boundaries. With the Heat Transfer Module, there are additional physics interfaces for surface-to-surface radiation that you can add to the model if needed. Best regards, Magnus
Posted: 11 months ago 2023/06/19 5:35 GMT-4
Hi Mohammed,
Magnus
Hi, Thanks for your reply I understand Hi Mohammed,
Magnus
Hi, Thanks for your reply, I understand. Best regards, Mohammed
>Hi Mohammed, > >With the Conjugate Heat Transfer multiphysics interface, you can add surface-to-ambient radiation to boundaries. With the Heat Transfer Module, there are additional physics interfaces for surface-to-surface radiation that you can add to the model if needed. > >Best regards, > >Magnus >Hi, Thanks for your reply I understand >Hi Mohammed, > >With the Conjugate Heat Transfer multiphysics interface, you can add surface-to-ambient radiation to boundaries. With the Heat Transfer Module, there are additional physics interfaces for surface-to-surface radiation that you can add to the model if needed. > >Best regards, > >Magnus Hi, Thanks for your reply, I understand. Best regards, Mohammed
Posted: 11 months ago 2023/06/19 12:26 GMT-4
Updated: 11 months ago 2023/06/26 3:34 GMT-4
Hi Mohammed,
Magnus
Hi Magnus, I have another question if you don't mind, do I also need to add an additional physics interface for heat conduction or it's already included in the Conjugate Heat Transfer Multiphysics?
>Hi Mohammed, > >With the Conjugate Heat Transfer multiphysics interface, you can add surface-to-ambient radiation to boundaries. With the Heat Transfer Module, there are additional physics interfaces for surface-to-surface radiation that you can add to the model if needed. > >Best regards, > >Magnus Hi Magnus, I have another question if you don't mind, do I also need to add an additional physics interface for heat conduction or it's already included in the Conjugate Heat Transfer Multiphysics? Best regards, Mohammed
