moving mesh - laminar flow+phase set
Hi, I’m using the multiphase flow with laminar flow and phase set models for simulating the process of filing a mould and then wiping the excess of fluid with a moving wipe (or blade), as show in the pdf file I use the moving mesh interface and added the automatic remeshing to the solver. Everything works until the time in which the blade “touches” the boundary of the semi-circle I used to define the initial shape of the fluid. If someone could give me some help on how to define the simulation so it does not crash, it would be great. Thank you.
0 Replies Last Post 2023/10/10 17:29 JST
Hello Fabricio Coelho
