difference of check and uncheck "generate default plots" when solving
I couldn't figure out what's the difference between check and uncheck "generate default plots". I filmed a video attached to this discussion, in which some details are shown to clarify.
1 Reply Last Post 2024/03/14 10:08 GMT-4
Magnus Ringh COMSOL Employee
Posted: 3 years ago 2024/03/14 10:08 GMT-4
Hi Haiyang,
When the Generate default plots check box is selected, default plots are generated when you first solve the model and are updated when you re-solve. If you change or remove such default plots, you need to right-click the Study node and choose Reset Default Plots first; otherwise they will not be added or modified to the original default plot settings when re-solving. The plot while solving in your movie is not affected by the default plot settings. It uses the plot group that you select under Results While Solving.
Magnus
Hi Haiyang, When the **Generate default plots** check box is selected, default plots are generated when you first solve the model and are updated when you re-solve. If you change or remove such default plots, you need to right-click the **Study** node and choose **Reset Default Plots** first; otherwise they will not be added or modified to the original default plot settings when re-solving. The plot while solving in your movie is not affected by the default plot settings. It uses the plot group that you select under **Results While Solving**. Best regards, Magnus
