Error using colormap Too many input arguments.
Hey everybody, Does anyone of you know the following error when working with the Matlab live link:
mphplot(model,'pg1','rangenum',1);
Error in .../mli/mphplot.p>l_colorlegend (line 1384)
Error in .../mli/mphplot.p>addplot (line 300)
Error in .../mli/mphplot.p>mphplot (line 154)
? Any suggestions about how to fix it are MOST welcome.
Cheers, Sabine
1 Reply Last Post 2013/01/09 2:17 JST
Posted: 1 decade ago 2013/01/09 2:17 JST
Hi again,
so after many hours of try-and-error, i know now that
mphplot(model,pg,'rangenum',1);
works NOT, anymore, if i use
"addpath(genpath('/users/me/myfolder'))"
which i used for analysis functions stored in that folder so i moved the functions to another folder, different to that my model.m is saved in, and everything works fine. (weirdly enough, for another model of mine, comsol has definitley no problem with the same command) Anyway, I am not sure if this is always the source of the error, since sometimes I ran the same model twice, and first it worked, then it didnt,...
I hope your errors behave nicer :)
Hi again, so after many hours of try-and-error, i know now that mphplot(model,pg,'rangenum',1); works NOT, anymore, if i use "addpath(genpath('/users/me/myfolder'))" which i used for analysis functions stored in that folder so i moved the functions to another folder, different to that my model.m is saved in, and everything works fine. (weirdly enough, for another model of mine, comsol has definitley no problem with the same command) Anyway, I am not sure if this is always the source of the error, since sometimes I ran the same model twice, and first it worked, then it didnt,... I hope your errors behave nicer :)
