Discussion Locked This discussion was locked by a forum moderator.
problem with contact pair-penalty factor setting
Hello everyone,
I am trying to model a contact problem into structural module application. I'd like to solve the contact problem without calculating the pressure at contact pair interface (I have disabled the augmented lagrangian solver). However, Comsol returns a convergence error. I think all this is due to the penalty factor assignment. By default it depends on the "augliter" (iteration which occur when the lagrangian solver is enabled).
Thus, question are: is there a way to solve the contact problem without calculate the pressure field at the coontact interface? How can I set the penalty factor value when the lagrangian solver is disabled?
Thanks for your attention!
Pasquale
27 Replies Last Post 2016/03/14 9:26 GMT-4
Remi Magnard COMSOL Employee
Posted: 2 decades ago 2009/06/25 11:41 GMT-4
Hello everyone,
Pasquale
Hello Pasquale,
Using a penalty function for contact problem is good alternative of the augmented Lagrangian method available in the structural mechanics module. This method (penalty function) is a bit less accurate than the augmented Lagrangian one as it allow penetration between the elastic body but it is also much more stable.
To use such a method in COMSOL you just need to replace the Contact normal penalty factor expression in the contact pair by the following expression : k/h
where k is a stiffness constant in the order of the stiffness of the material.
Then remove the contact pressure variable from the solve for list in the solver manager.
Finally deselect the augmented lagrangian solver option in the solver parameters (stationary page).
You will then see that the higher k the lower the penetration between the two elastic material, but also the lower k the smoother the convergence
Remi Magnard
[QUOTE] Hello everyone, I am trying to model a contact problem into structural module application. I'd like to solve the contact problem without calculating the pressure at contact pair interface (I have disabled the augmented lagrangian solver). However, Comsol returns a convergence error. I think all this is due to the penalty factor assignment. By default it depends on the "augliter" (iteration which occur when the lagrangian solver is enabled). Thus, question are: is there a way to solve the contact problem without calculate the pressure field at the coontact interface? How can I set the penalty factor value when the lagrangian solver is disabled? Thanks for your attention! Pasquale [/QUOTE] Hello Pasquale, Using a penalty function for contact problem is good alternative of the augmented Lagrangian method available in the structural mechanics module. This method (penalty function) is a bit less accurate than the augmented Lagrangian one as it allow penetration between the elastic body but it is also much more stable. To use such a method in COMSOL you just need to replace the Contact normal penalty factor expression in the contact pair by the following expression : k/h where k is a stiffness constant in the order of the stiffness of the material. Then remove the contact pressure variable from the solve for list in the solver manager. Finally deselect the augmented lagrangian solver option in the solver parameters (stationary page). You will then see that the higher k the lower the penetration between the two elastic material, but also the lower k the smoother the convergence Remi Magnard
Posted: 2 decades ago 2009/06/25 12:48 GMT-4
Hello Remi,
thanks for your fast reply!
I have applied your procedure on a 2D example and it seems to work very well. I have set the stiffness value equal to the young's modulus (I have assumed an isotropic elastic material).
I will test as soon this procedure on a 3D model and I will update you about results.
I am programming a Matlab-Comsol automatic application. By using Matlab a "perturbed" geometry is generated, by using a morphing mesh approach. I am looking for simulate the assembly process among perturbed parts (clamping, fastening and releasing). I must avoid any solver-error during the automatic calculation. As you suggest, the penalty method is more stable than the lagrange one and thus the automatic procedure may be performed with few problems by using a penalty function.
Thanks again
Pasquale
P.S.: "perturbed" parts are like-real parts which may come from forming processes and are used in automobile applications.
Hello Remi, thanks for your fast reply! I have applied your procedure on a 2D example and it seems to work very well. I have set the stiffness value equal to the young's modulus (I have assumed an isotropic elastic material). I will test as soon this procedure on a 3D model and I will update you about results. I am programming a Matlab-Comsol automatic application. By using Matlab a "perturbed" geometry is generated, by using a morphing mesh approach. I am looking for simulate the assembly process among perturbed parts (clamping, fastening and releasing). I must avoid any solver-error during the automatic calculation. As you suggest, the penalty method is more stable than the lagrange one and thus the automatic procedure may be performed with few problems by using a penalty function. Thanks again Pasquale P.S.: "perturbed" parts are like-real parts which may come from forming processes and are used in automobile applications.
Posted: 2 decades ago 2010/02/27 17:31 GMT-5
Pasquale:
Where is the Contact normal penalty factor expression located?
Have you try to use conact pair in an analysis with two types of physics?
Sharon
Hello Remi,
Thanks again
Pasquale
Pasquale: Where is the Contact normal penalty factor expression located? Have you try to use conact pair in an analysis with two types of physics? Sharon [QUOTE] Hello Remi, thanks for your fast reply! I have applied your procedure on a 2D example and it seems to work very well. I have set the stiffness value equal to the young's modulus (I have assumed an isotropic elastic material). I will test as soon this procedure on a 3D model and I will update you about results. I am programming a Matlab-Comsol automatic application. By using Matlab a "perturbed" geometry is generated, by using a morphing mesh approach. I am looking for simulate the assembly process among perturbed parts (clamping, fastening and releasing). I must avoid any solver-error during the automatic calculation. As you suggest, the penalty method is more stable than the lagrange one and thus the automatic procedure may be performed with few problems by using a penalty function. Thanks again Pasquale P.S.: "perturbed" parts are like-real parts which may come from forming processes and are used in automobile applications. [/QUOTE]
Posted: 2 decades ago 2010/02/28 3:42 GMT-5
Hi Sharon,
go to physics>boundary settings>pairs>contact>"pn". Make sure to create at least a contact pair before.
If you like to solve the contact problem just by using the penalty method, type "E/h" into "pn" label. "E" is the young modulus, while "h" is the mean mesh size.
I guess that this approach may be general. I mean that you can solve any kind of multiphysic problem.
If you have a specific problem, please post much more details, so I can better understand your problem.
I hope this is helpful,
Pasquale
Hi Sharon, go to physics>boundary settings>pairs>contact>"pn". Make sure to create at least a contact pair before. If you like to solve the contact problem just by using the penalty method, type "E/h" into "pn" label. "E" is the young modulus, while "h" is the mean mesh size. I guess that this approach may be general. I mean that you can solve any kind of multiphysic problem. If you have a specific problem, please post much more details, so I can better understand your problem. I hope this is helpful, Good luck Pasquale
Posted: 2 decades ago 2010/02/28 13:13 GMT-5
Pasquale:
Thanks for the tip. It works well.
Sharon
Pasquale: Thanks for the tip. It works well. Sharon
Posted: 2 decades ago 2010/11/02 11:53 GMT-4
Do I need to define k and h myself, or they are already defined?
Where is the contact pressure variable and also I can't find the Lagrangian solver option in order to deselect it.
Thank you!
Hi, Do I need to define k and h myself, or they are already defined? Where is the contact pressure variable and also I can't find the Lagrangian solver option in order to deselect it. Thank you!
Posted: 1 decade ago 2011/04/13 22:33 GMT-4
Hello, Remi!
In the help file, it said:"Note that in the augmented Lagrangian method, the value of the penalty factor does not affect the accuracy of the final solutin, like it does in the penalty method". I know the ugmented Lagrangian method and the penalty method are different. But I am wondering that did the contact normal penalty factor only affect the penalty method but not the augmented Lagrangian method.
In the augmented Lagrangian method, the expression of "pn" is "E_smsld/hmin_cp1_smsld*min(1e-3*5^auglagiter,1)". What does the expreesion mean? Is the normal penalty factor have no affection on the convergence of the augmented Lagrangian method?
Any advices will be helpful and appreciate! Thanks in advance!
Best wishes!
Yajuan
Hello, Remi! In the help file, it said:"Note that in the augmented Lagrangian method, the value of the penalty factor does not affect the accuracy of the final solutin, like it does in the penalty method". I know the ugmented Lagrangian method and the penalty method are different. But I am wondering that did the contact normal penalty factor only affect the penalty method but not the augmented Lagrangian method. In the augmented Lagrangian method, the expression of "pn" is "E_smsld/hmin_cp1_smsld*min(1e-3*5^auglagiter,1)". What does the expreesion mean? Is the normal penalty factor have no affection on the convergence of the augmented Lagrangian method? Any advices will be helpful and appreciate! Thanks in advance! Best wishes! Yajuan
Posted: 1 decade ago 2011/08/17 12:19 GMT-4
Hi everybody,
I am using comsol 4.2 to simulate a contact problem. When I choose the penalty factor as E/k (I know elastic modulus and I get average mesh size from statics), the result is so strange. I would rather rely on what is written in front of Pn but just multiply it by a constant like (1/3). Now my question is
Is the string written in front of Pn with the dimension of N/M^3 somehow calculating the E/K? Does anybody knows the physical relationship of this constant that I introduced and got convergence (1/3) with the special materials or physics that are used?
Yours,
Marjan
Hi everybody, I am using comsol 4.2 to simulate a contact problem. When I choose the penalty factor as E/k (I know elastic modulus and I get average mesh size from statics), the result is so strange. I would rather rely on what is written in front of Pn but just multiply it by a constant like (1/3). Now my question is Is the string written in front of Pn with the dimension of N/M^3 somehow calculating the E/K? Does anybody knows the physical relationship of this constant that I introduced and got convergence (1/3) with the special materials or physics that are used? Yours, Marjan
Posted: 1 decade ago 2011/08/17 14:02 GMT-4
The default COMSOL expression in front of Pn has two components. The first part (solid.Eequ/solid.hmin_dst) is a geometry/material part of the same form as the E/k expression you mentioned that is automated to get good estimates for E and k. The material stiffness Solid.Eequ is automatically calculated based on the material of the destination surface, and the minimum element size solid.hmin_dst is automatically calculated also from the destination surface. The second part of the Pn expression (min(1e-3*5^segiter, 1)) is an iteration dependent term that reduces the severity of the contact condition by using a lower penalty parameter in the first few iterations .
It is a good idea to scale this expression up or down based on two factors: (i) ease of convergence and (ii) solution accuracy. The lower penalty usually leads to faster convergence, but more interpenetration between the surfaces, which is a deviation from the exact contact constraints. I find it also useful in some problems to remove the iteration part of the expression (min(1e-3*5^segiter, 1)).
Nagi Elabbasi
Veryst Engineering
The default COMSOL expression in front of Pn has two components. The first part (solid.Eequ/solid.hmin_dst) is a geometry/material part of the same form as the E/k expression you mentioned that is automated to get good estimates for E and k. The material stiffness Solid.Eequ is automatically calculated based on the material of the destination surface, and the minimum element size solid.hmin_dst is automatically calculated also from the destination surface. The second part of the Pn expression (min(1e-3*5^segiter, 1)) is an iteration dependent term that reduces the severity of the contact condition by using a lower penalty parameter in the first few iterations . It is a good idea to scale this expression up or down based on two factors: (i) ease of convergence and (ii) solution accuracy. The lower penalty usually leads to faster convergence, but more interpenetration between the surfaces, which is a deviation from the exact contact constraints. I find it also useful in some problems to remove the iteration part of the expression (min(1e-3*5^segiter, 1)). Nagi Elabbasi Veryst Engineering
Posted: 1 decade ago 2011/08/17 17:49 GMT-4
Dear Nagi,
Thanks alot. I had thought that h is the average mesh size but now I learned that it is min mesh size of slave.It was a very good explanation of what I see as pn. The iteration part was also a big question mark that now is clear. Thanks again :).
Yours,
Marjan
Dear Nagi, Thanks alot. I had thought that h is the average mesh size but now I learned that it is min mesh size of slave.It was a very good explanation of what I see as pn. The iteration part was also a big question mark that now is clear. Thanks again :). Yours, Marjan
Posted: 1 decade ago 2011/12/12 8:04 GMT-5
Hi Everybody,
I would like to try Remi 's comments and therefore I have a question and a request :).
1- what do you call solver manager?
2- I cannot find augmented lagrangian solver option in stationary page. Would you please help me to find it?
Yours,
Marjan
Remi Magnard
Hi Everybody, I would like to try Remi 's comments and therefore I have a question and a request :). 1- what do you call solver manager? 2- I cannot find augmented lagrangian solver option in stationary page. Would you please help me to find it? Yours, Marjan [QUOTE] [QUOTE] Using a penalty function for contact problem is good alternative of the augmented Lagrangian method available in the structural mechanics module. This method (penalty function) is a bit less accurate than the augmented Lagrangian one as it allow penetration between the elastic body but it is also much more stable. To use such a method in COMSOL you just need to replace the Contact normal penalty factor expression in the contact pair by the following expression : k/h where k is a stiffness constant in the order of the stiffness of the material. Then remove the contact pressure variable from the solve for list in the solver manager. Finally deselect the augmented lagrangian solver option in the solver parameters (stationary page). You will then see that the higher k the lower the penetration between the two elastic material, but also the lower k the smoother the convergence Remi Magnard [/QUOTE] --
Posted: 1 decade ago 2012/03/28 5:25 GMT-4
Hi Remi,
I had a problem in fixing the contact parameters of my model that contains a contact between a hyperelastic material and an elastic material. I tried to use your suggestion "penalty method". however, when I enter the initial values of the E for the slave material "hyperealstic" divided by its maximum mesh size, the convergence will not occur. I am using the weak constraint in the properties, does that affect my model?
Sincerely,
Ahmad
Hi Remi, I had a problem in fixing the contact parameters of my model that contains a contact between a hyperelastic material and an elastic material. I tried to use your suggestion "penalty method". however, when I enter the initial values of the E for the slave material "hyperealstic" divided by its maximum mesh size, the convergence will not occur. I am using the weak constraint in the properties, does that affect my model? Sincerely, Ahmad
Posted: 1 decade ago 2012/03/28 22:38 GMT-4
Hi everyone
I have a model that contains an elastic beam that when deflected comes in contact with two different hyperelastic materials one on each side. No matter how I change the contact parameters (i.e. increasing the penalty factors or the initial pressure) still convergence do not occurred. Is it possible to simulate such a case in Comsol or not? cause I even tried different conditions but it still do not work. And I tried to apply the penalty method instead of the augmented method but still not working. honestly do not know what to do with the model, and I have very important dead line in two weeks. so please if you have any idea that could help let me know.
Ahmad Atieh
Hi everyone I have a model that contains an elastic beam that when deflected comes in contact with two different hyperelastic materials one on each side. No matter how I change the contact parameters (i.e. increasing the penalty factors or the initial pressure) still convergence do not occurred. Is it possible to simulate such a case in Comsol or not? cause I even tried different conditions but it still do not work. And I tried to apply the penalty method instead of the augmented method but still not working. honestly do not know what to do with the model, and I have very important dead line in two weeks. so please if you have any idea that could help let me know. Thanks Ahmad Atieh
Posted: 1 decade ago 2012/03/29 4:20 GMT-4
hi,
if you can, please attach your model so we can see better your settings.
Pasquale
hi, if you can, please attach your model so we can see better your settings. Pasquale
Posted: 1 decade ago 2012/03/29 6:14 GMT-4
Hi Dear Ahmad,
In general it is possible to simulate your problem with Comsol . Only thing is that, contact problems including soft materials are a little tricky. I mean it is very sensitive to the problem definition e.g. the scale of dependent variables for example. I also would recommend that you attach your model.
All the best,
Marjan
Hi Dear Ahmad, In general it is possible to simulate your problem with Comsol . Only thing is that, contact problems including soft materials are a little tricky. I mean it is very sensitive to the problem definition e.g. the scale of dependent variables for example. I also would recommend that you attach your model. All the best, Marjan
Posted: 1 decade ago 2012/03/31 22:40 GMT-4
Hi Pasquale & Marjan
I am really sorry for the late replay. And I really appreciate your welling to help. Kindly, find attached two models of my work. it is a tactile sensor in contact with silicone rubber ( artificial tissue). the models are built in comsol 4.1 version. the model with extra layers resemble the experimental test where the extra layers work as two jacks one to be a substrate to the sensor and the other push the tissue against the sensor. and the sensor has a softer silicone rubber in his structure under the beam. I made my best to use mechanical properties in simulation similar to the properties of the real components, including the friction constants even. However I am still new with the comsol and I hope that I didn't do any stupid mistakes in building the models.
If any one of them could work , then it would be sufficient to me.
If you needed any clarification about the model components please let me know.
Many Thanks
Ahmad
Hi Pasquale & Marjan I am really sorry for the late replay. And I really appreciate your welling to help. Kindly, find attached two models of my work. it is a tactile sensor in contact with silicone rubber ( artificial tissue). the models are built in comsol 4.1 version. the model with extra layers resemble the experimental test where the extra layers work as two jacks one to be a substrate to the sensor and the other push the tissue against the sensor. and the sensor has a softer silicone rubber in his structure under the beam. I made my best to use mechanical properties in simulation similar to the properties of the real components, including the friction constants even. However I am still new with the comsol and I hope that I didn't do any stupid mistakes in building the models. If any one of them could work , then it would be sufficient to me. If you needed any clarification about the model components please let me know. Many Thanks Ahmad
Posted: 1 decade ago 2012/04/01 7:27 GMT-4
Hi Ahmad,
there are several things that you should figure out (I am referring to the semplified model).
1. when handling contact pairs, the weak of constraint could make the solution not so stable (the stiffness matrix becomes ill-conditioned). This means that you should assure that all domains have all rigid motions avoided. In your application you can do this just by observing that the model has a symmetric wrt the middle plane (have a look to the attached modified model).
2. just to fine-tune all solution parameters, it is better to use a linear mesh (linear discretization both for displacement and contact pressure) at the beginning.
3. set a properly value of the initial contact pressure. As in your model the three domains are still in contact in the un-deformed configuration, you should set a small initial contact pressure (say 1e-3).
4. define a parametric solver to fine-tune the load step (use a small parameter-step if the convergence does not appear).
5. in my experience, the penalty value can be set as E/h, where "E" is the stiffness of the softer material (the hyperelastic material in your model), while "h" is the mean mesh size at contact interface.
Hoping this help, regards.
Pasquale
Hi Ahmad, there are several things that you should figure out (I am referring to the semplified model). 1. when handling contact pairs, the weak of constraint could make the solution not so stable (the stiffness matrix becomes ill-conditioned). This means that you should assure that all domains have all rigid motions avoided. In your application you can do this just by observing that the model has a symmetric wrt the middle plane (have a look to the attached modified model). 2. just to fine-tune all solution parameters, it is better to use a linear mesh (linear discretization both for displacement and contact pressure) at the beginning. 3. set a properly value of the initial contact pressure. As in your model the three domains are still in contact in the un-deformed configuration, you should set a small initial contact pressure (say 1e-3). 4. define a parametric solver to fine-tune the load step (use a small parameter-step if the convergence does not appear). 5. in my experience, the penalty value can be set as E/h, where "E" is the stiffness of the softer material (the hyperelastic material in your model), while "h" is the mean mesh size at contact interface. Hoping this help, regards. Pasquale
Posted: 1 decade ago 2012/04/01 16:58 GMT-4
Hi Dear Ahmad,
I completely agree with the previous post. In Comsol, the displacement discritization should not have higher order than pressure one. It works almost fine for me to choose the order of discritization of displacement 4 and the order of contact pressure discritization 1. I am also going to try setting both to 1 :). That was a good point. Thanks Pasquale.
Concerning a contact pressure, I suggest that you take a look at cylinder roller example in the library. It helps the solver to converge better in case that you introduce a small pressure in contact area.
Good luck,
Marjan
Hi Dear Ahmad, I completely agree with the previous post. In Comsol, the displacement discritization should not have higher order than pressure one. It works almost fine for me to choose the order of discritization of displacement 4 and the order of contact pressure discritization 1. I am also going to try setting both to 1 :). That was a good point. Thanks Pasquale. Concerning a contact pressure, I suggest that you take a look at cylinder roller example in the library. It helps the solver to converge better in case that you introduce a small pressure in contact area. Good luck, Marjan
Posted: 1 decade ago 2012/04/01 23:05 GMT-4
Hi Pasquale,
Thanks for the quick replay. and I am happy that it works now up to 0.3 para (i.e. 0.3 N) at least. I am trying to find where I can play with the linear mesh (linear discretization both for displacement and contact pressure) at the beginning. I am not quite sure if what I found and change is the one that you meant. I activate the "show more options" in the model builder window and the I was able only to select the discretization type with out any order or values. Is that what did you mean? Sorry again I am really new to the 4.1 version of the software.
Ahmad
Hi Pasquale, Thanks for the quick replay. and I am happy that it works now up to 0.3 para (i.e. 0.3 N) at least. I am trying to find where I can play with the linear mesh (linear discretization both for displacement and contact pressure) at the beginning. I am not quite sure if what I found and change is the one that you meant. I activate the "show more options" in the model builder window and the I was able only to select the discretization type with out any order or values. Is that what did you mean? Sorry again I am really new to the 4.1 version of the software. Thanks Ahmad
Posted: 1 decade ago 2012/04/01 23:35 GMT-4
Hi Marjan and , Pasquale
Thanks for the interests and help. I am trying to get what exactly u meant by the order of the discritization and where I can change it.
Also, I need to have the solution up to 5N loading, which means according to the model that I upload I have either to extend the para up to 5, or to replace the loading boundary condition in y axis with (- (16.67/568)*para) [N/mm^2]. and when I tried both of them the solution didn't wasn't converged after (0.35 N). what is the reason for that?
Best regards
Ahamad
Hi Marjan and , Pasquale Thanks for the interests and help. I am trying to get what exactly u meant by the order of the discritization and where I can change it. Also, I need to have the solution up to 5N loading, which means according to the model that I upload I have either to extend the para up to 5, or to replace the loading boundary condition in y axis with (- (16.67/568)*para) [N/mm^2]. and when I tried both of them the solution didn't wasn't converged after (0.35 N). what is the reason for that? Thanks Best regards Ahamad
Posted: 1 decade ago 2012/04/02 4:45 GMT-4
Hi Ahmad,
Below the material icon, you have main solid mechanics (where there is sound waves and...). Click on solid mechanics. Somewhere there you have displacement. There adjust discritization to quadratic.
Then below the solid mechanics main icon, there is the contact icon, if you click you will find again discritization. Adjust it to linear.
If it did not converged, change the contact discritization to 1. However the discritization of displacement is always higher.
This affects the shape function and convergence as well.
All the best,
Marjan
Hi Ahmad, Below the material icon, you have main solid mechanics (where there is sound waves and...). Click on solid mechanics. Somewhere there you have displacement. There adjust discritization to quadratic. Then below the solid mechanics main icon, there is the contact icon, if you click you will find again discritization. Adjust it to linear. If it did not converged, change the contact discritization to 1. However the discritization of displacement is always higher. This affects the shape function and convergence as well. All the best, Marjan
Posted: 1 decade ago 2012/04/02 5:03 GMT-4
Hi Again Ahmad,
As long as your mesh is not moving, use extension instead of parametric sweep. In parametric sweep for every parameter the solver solves the problem from beginning but in extension, the previous results is the answer for next step.
Marjan
Hi Again Ahmad, As long as your mesh is not moving, use extension instead of parametric sweep. In parametric sweep for every parameter the solver solves the problem from beginning but in extension, the previous results is the answer for next step. Good luck Marjan
Hi Again Ahmad,
Marjan
Posted: 1 decade ago 2012/05/25 13:54 GMT-4
I also am trying to simulate contact between stent device and blood vessel. Until now I didn't get any good results, all case I got convergence errors. I consider every aspects you guys posted here. However, I am still struggling with this model. Right now I have no idea what cause convergence problems. Setting contact pair, meshing and solver setting looks fine, but why convergence strat oscillation up to very high value or down low finally not converge with current setting up???
Concerning about constraints before in contact between two parts, I already test each part is fully constraint or not. I found no convergence issue without contact problem.
Is there any other recommendation about this problem?
I also am trying to simulate contact between stent device and blood vessel. Until now I didn't get any good results, all case I got convergence errors. I consider every aspects you guys posted here. However, I am still struggling with this model. Right now I have no idea what cause convergence problems. Setting contact pair, meshing and solver setting looks fine, but why convergence strat oscillation up to very high value or down low finally not converge with current setting up??? Concerning about constraints before in contact between two parts, I already test each part is fully constraint or not. I found no convergence issue without contact problem. Is there any other recommendation about this problem?
Posted: 1 decade ago 2012/05/25 19:57 GMT-4
Hi dear Sungho,
Are you checking the box of creat creat pair at the end of Geometry? Have you set your constraints in a good way? Are you using a parametric solver? if yes, start with very fine indentation and make your steps reseanably small. What about the introduction of a pre defined pressure in area of contact? it helps alot. You also can check and use manual scaling in solver. It is hard to think about your problem without seeing the model. Using weak constrains for the moving object, I mean for source sometimes helps alot. I hope at least I can give you some idea.
Yours,
Marjan
Hi dear Sungho, Are you checking the box of creat creat pair at the end of Geometry? Have you set your constraints in a good way? Are you using a parametric solver? if yes, start with very fine indentation and make your steps reseanably small. What about the introduction of a pre defined pressure in area of contact? it helps alot. You also can check and use manual scaling in solver. It is hard to think about your problem without seeing the model. Using weak constrains for the moving object, I mean for source sometimes helps alot. I hope at least I can give you some idea. Yours, Marjan
Posted: 10 years ago 2016/03/13 12:11 GMT-4
hi,
Pasquale
Hi Pasquale
I have a 2D model costituited by elastomer (rectangular block) that sliding on rigid (square) pyramidal substrate; how can i estimate effective contact area of elastomer? How can i set Contact penality setting? i attach my file, where i wrong? Please someone answer me and correct the error, i'm new of software.
thank you previously
[QUOTE] hi, if you can, please attach your model so we can see better your settings. Pasquale [/QUOTE] Hi Pasquale I have a 2D model costituited by elastomer (rectangular block) that sliding on rigid (square) pyramidal substrate; how can i estimate effective contact area of elastomer? How can i set Contact penality setting? i attach my file, where i wrong? Please someone answer me and correct the error, i'm new of software. thank you previously
Posted: 10 years ago 2016/03/14 9:26 GMT-4
Regarding the last model file that has been sent here: There are several issues with the file, some of the more apparent are that you are applying a velocity boundary condition for a stationary problem and that you are trying to model point-to-plane contact. Rather than modeling contact between a point and a plane, add a small fillet to the sharp corners here so that you get surface-to-surface contact, rather than the (singular) point-to-surface contact. The mesh is also far to coarse,
More generally regarding this thread: The previous discussions in this thread do refer to much earlier versions of the software. We do encourage users modeling contact to be using the latest version of the software, as there have been many algorithmic improvements since these original discussions. Much of the technical discussions in this thread are now outdated. We will leave this thread up for historical purposes but will lock the thread for further comments. Please of course feel free to open new threads and refer back to this if needed.
Regards.
Henrik
Hi, Regarding the last model file that has been sent here: There are several issues with the file, some of the more apparent are that you are applying a velocity boundary condition for a stationary problem and that you are trying to model point-to-plane contact. Rather than modeling contact between a point and a plane, add a small fillet to the sharp corners here so that you get surface-to-surface contact, rather than the (singular) point-to-surface contact. The mesh is also far to coarse, More generally regarding this thread: The previous discussions in this thread do refer to much earlier versions of the software. We do encourage users modeling contact to be using the latest version of the software, as there have been many algorithmic improvements since these original discussions. Much of the technical discussions in this thread are now outdated. We will leave this thread up for historical purposes but will lock the thread for further comments. Please of course feel free to open new threads and refer back to this if needed. Regards. Henrik
