Magnetostrictive generator harvester
hello, I have a magnetostrictive generator and I have a problem with the material itself. The main problem would be the fact that the magnetostrictive material does not induce a magnetic field in my coil. The only induced magnetic field is the one from the permanent magnet. Normally I should have somewhere 12 V. Can someone look over the simulation and give me some advice or explain what the problem is?
3 Replies Last Post 2024/06/18 13:32 GMT-4
Posted: 11 months ago 2024/06/18 6:09 GMT-4
Updated: 11 months ago 2024/06/18 6:17 GMT-4
George,
There is no piezomagnetic domain in the solid node.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
George, There is no piezomagnetic domain in the solid node. Cheers Edgar
Posted: 11 months ago 2024/06/18 10:48 GMT-4
George,
Cheers Edgar
Okay but after put a solid node ,i need two voigt matrix .Do you can tell me how to define two matrix ?Compliance matrice,Voigt notatio and Piezomagnetic coupling matrix ,Voigt notation
>George, > >There is no piezomagnetic domain in the solid node. > >Cheers >Edgar Okay but after put a solid node ,i need two voigt matrix .Do you can tell me how to define two matrix ?Compliance matrice,Voigt notatio and Piezomagnetic coupling matrix ,Voigt notation
Posted: 11 months ago 2024/06/18 13:32 GMT-4
Yes, it seems that in that case of nonlinear magnetostriction the piezomagnetic domain is not required as the multiphysics coupling is doing the job. Keep in mind that the Villari effect is not generating a magnetic field in the magnetostrictor. The mechanical strain modifies the magnetic properties of the material and this modulates the DC bias field. Without the bias field, no magnetic field is generated.
Edgar J. Kaiser
www.emphys.com
