Handling Geometry or Meshing Failures in MATLAB-COMSOL Model
Posted 2025/04/16 15:42 GMT-5 Geometry, Mesh, Modeling Workflow Version 6.2 0 Replies
Hi all,
I’m running a MATLAB-COMSOL model where I update my design variables using a command like:
% Set the variables nPoints = size(xy, 1); % Number of point pairs for i = 1:nPoints xi = xy(i,1); % x-coordinate yi = xy(i,2); % y-coordinate
model.param.set(sprintf('x%d', i), sprintf('%0.4f [mm]', xi));
model.param.set(sprintf('y%d', i), sprintf('%0.4f [mm]', yi));
end
However, in some cases, certain combinations of design variables lead to non-viable geometries. As a result, the model fails either during geometry generation or meshing, and I get an error when trying to evaluate:'
mphglobal(model, 'solid.LFcrit');
To handle this, I would like to check whether the geometry and mesh were successfully generated before calling mphglobal. If they weren’t, I want to skip that part so that MATLAB can continue iterating without crashing the whole optimization loop.
Is there a recommended way to check the status of geometry and mesh generation in COMSOL via the MATLAB API?
Any suggestions would be much appreciated!
Best regards, Mirhan
Hello Mirhan Özdemir
