Hello Andy Huang
2014/06/06 23:39 JST
I know this discussion is quite old but I was wondering if you found a solution (or if someone else has any suggestion) as I'm having exactly the same problem. I am using the same module (Richards' equation) and the same version of COMSOL (4.3); I am analysing water flow through an embankment during a flood event and I would like to switch boundary condition from "no flow" to "pressure head" when the pressure head at the toe of the embankment becomes positive.
I would also like to automatically change the boundary condition from "hydraulic head" to "no flow" according to the elevation of the points on a boundary. I'll try to explain this point more clearly: to represent the rising water level on the river side of the embankment I am applying a boundary condition in terms of hydraulic head varying over time (i.e. the hydrograph of my flood event); anyway on the portion of the embankment boundary which is not wet by the river, i.e. when the elevation y is more than the hydraulic head that I am applying, I need a "no flow" boundary condition. I have managed to change the value of the hydraulic head according to the elevation with a simple "if" statement (if(y<H(t),H(t),0)), but in the "else" scenario I need to change the type of boundary condition rather than its value.
Is there any way to do this? I was thinkink about a "conditional enabling", where I could enable the boundary condition "no flow" on the boundary only if y>H(t) and override the hydraulic head boundary condition only in this case, but I've found nothing about it. Could anyone have suggestion about this?
I would really appreciate any help. Thank you.
I would also like to automatically change the boundary condition from "hydraulic head" to "no flow" according to the elevation of the points on a boundary. I'll try to explain this point more clearly: to represent the rising water level on the river side of the embankment I am applying a boundary condition in terms of hydraulic head varying over time (i.e. the hydrograph of my flood event); anyway on the portion of the embankment boundary which is not wet by the river, i.e. when the elevation y is more than the hydraulic head that I am applying, I need a "no flow" boundary condition. I have managed to change the value of the hydraulic head according to the elevation with a simple "if" statement (if(yH(t) and override the hydraulic head boundary condition only in this case, but I've found nothing about it. Could anyone have suggestion about this?
2014/06/10 18:15 JST
It is better to use mixed boundary condition or you can define step function for the embankment.
[QUOTE]
[/QUOTE]
2014/06/18 19:13 JST
Thanks for your reply, but what do you mean with mixed boundary condition? How can I apply this in version 4.3?
