why COMSOL is solving so slowly
Posted 2013/09/03 12:03 JST Heat Transfer & Phase Change, Studies & Solvers Version 4.3b 5 Replies
Hi All,
I am running a case with radiation heat transfer. The 3D geometry is quite simple. Number of degrees of freedom solved for: 56826 (plus 39748 internal DOFs), and element number is around 24K. I use the segragated solver.
And I found that: the time for assembly in each step is around 15 minutes, and memory usage seems OK, around 8GB.
I wonder whether this calculation speed is normal or not.
Thanks.
Thanks.
5 Replies Last Post 2013/09/06 15:54 JST
