Non-Isothermal flow module issues
Hi, I am trying to model a single channel of a typical pressurized water reactor, considering three physics, the point kinetics model for the calculation of energy generated inside the fuel pellet, the heat transfer, and the turbulent flow of the coolant water.
Please take a look at the attached two files. In the first file, I used the Non-Isothermal flow (nitf) k-epsilon model, and implemented the point kinetics model by the Global node, and the it works! However, if I change the heat transport turbulence model from "Kays-Crawford" to "Extended Kays-Crawford" option, it does not work!
The only difference between the first and second file, is that, I put the ODE equation outside of the Non-Isothermal flow (nitf) module, and it could not converge!
Could anyone explain to me why the above things happen and what mistakes I have made there?
Thanks.
Lei
6 Replies Last Post 2014/01/30 7:20 JST
Luke Gritter Certified Consultant
Posted: 1 decade ago 2014/01/30 0:33 JST
Lei,
When you use the Global ODEs and DAEs interface, the software generates slightly different default solver settings compared to when you add the global equations in the Non-Isothermal Flow interface. For the case with the Global ODEs and DAEs interface, the error estimation (under Advanced on the Time-Dependent Solver node in the solver sequence) is set to "Include algebraic", while in the other case it is set to "Exclude algebraic". This solver setting is the cause of the different behavior of the time-dependent solver in the two models.
Luke Gritter
AltaSim Technologies
Lei, When you use the Global ODEs and DAEs interface, the software generates slightly different default solver settings compared to when you add the global equations in the Non-Isothermal Flow interface. For the case with the Global ODEs and DAEs interface, the error estimation (under Advanced on the Time-Dependent Solver node in the solver sequence) is set to "Include algebraic", while in the other case it is set to "Exclude algebraic". This solver setting is the cause of the different behavior of the time-dependent solver in the two models. -- Luke Gritter AltaSim Technologies
Posted: 1 decade ago 2014/01/30 1:11 JST
Hi, Luke:
Thank you for your reply. I tried changing the Advanced option from "Include algebraic" to "Exclude algebraic", and it is working the same way as using the Global node.
Next, I want to add a temperature feedback relation into the system, in the sense that if the temperature rises due to the power (heat source) increase, it will give certain feedback reactivity. In my model, I take average temperature over the entire domain to form a feedback reactivity (defined as a variable), then use the variable to get the new reactivity "rho" as input condition for calculation of the power, generating new heat source, thus influencing the heat transfer solutions. However, the coupled system does not seem to compute.
The error message is:
Repeated error test failures. May have reached a singularity.
Time : 0.06456702759609664
See the attached file.
Is there anything that I messed up here? Could you please help me with that?
Thanks.
Lei
Hi, Luke: Thank you for your reply. I tried changing the Advanced option from "Include algebraic" to "Exclude algebraic", and it is working the same way as using the Global node. Next, I want to add a temperature feedback relation into the system, in the sense that if the temperature rises due to the power (heat source) increase, it will give certain feedback reactivity. In my model, I take average temperature over the entire domain to form a feedback reactivity (defined as a variable), then use the variable to get the new reactivity "rho" as input condition for calculation of the power, generating new heat source, thus influencing the heat transfer solutions. However, the coupled system does not seem to compute. The error message is: Repeated error test failures. May have reached a singularity. Time : 0.06456702759609664 Last time step is not converged. See the attached file. Is there anything that I messed up here? Could you please help me with that? Thanks. Lei
Posted: 1 decade ago 2014/01/30 5:44 JST
Lei,
Your feedback term is driving your heat source to infinity, so there is clearly something non-physical in your implementation of the physics. This is the cause of the convergence failure.
Luke Gritter
Lei, Your feedback term is driving your heat source to infinity, so there is clearly something non-physical in your implementation of the physics. This is the cause of the convergence failure. -- Luke Gritter AltaSim Technologies
Posted: 1 decade ago 2014/01/30 5:48 JST
Luke,
I see that problem now. It should be the opposite sign. OK, it is working now. Thanks for pointing it out.
By the way, do you know the reason for the error from changing the heat transport turbulence model from "Kays-Crawford" to "Extended Kays-Crawford" option?
Lei
Luke, I see that problem now. It should be the opposite sign. OK, it is working now. Thanks for pointing it out. By the way, do you know the reason for the error from changing the heat transport turbulence model from "Kays-Crawford" to "Extended Kays-Crawford" option? Lei
Posted: 1 decade ago 2014/01/30 6:51 JST
Lei,
When you use the Extended Kays-Crawford model for the turbulent Prandtl number, you must manually define a "Reynolds number at infinity" on the Fluid node. Make sure that you have entered an appropriate value for this Re - if this is left at the default value of zero, it will cause an error.
Luke Gritter
Lei, When you use the Extended Kays-Crawford model for the turbulent Prandtl number, you must manually define a "Reynolds number at infinity" on the Fluid node. Make sure that you have entered an appropriate value for this Re - if this is left at the default value of zero, it will cause an error. -- Luke Gritter AltaSim Technologies
Posted: 1 decade ago 2014/01/30 7:20 JST
Luke,
You are right! It definitely needs to be set to some reasonable value.
Thank you for your help!
Lei
Luke, You are right! It definitely needs to be set to some reasonable value. Thank you for your help! Lei
