Error 6177
Posted 2010/06/12 1:20 GMT-4 0 Replies
For some reason i could not reply to the thread , so i am starting as a new thread.
I am also getting the same error 6177 when solving for Time Harmonic mode, but if i run with Time Harmonic electric currents its not giving the error, Any body got any solution to avoid this 6177 error on Time Harmonic mode.
Thanks and Regards
I want to see eddy current in a metal by magnetic field of an AC voltage coil in 1MHz frequency in time harmonic mode but Comsol gives me Error:6177 (matrix has zero on diagonal. )
What can I do to solve this problem???
Reply | Reply with Quote | Send private message | Report Abuse
June 2, 2010 1:12pm UTC in response to Saber Behkami
Re: error 6177
Hi did you find solution for the problem you are getting i.e. error 6177?
If so kindly let me know.
I am also getting the same problem
-Nagesh..
June 2, 2010 2:23pm UTC in response to nageswara rao peela
Re: error 6177
When the equations have a structure such that the stiffness matrix (Jacobian matrix) has zeros on the diagonal, it is not possible to use the following linear system solvers/ preconditioners/smoothers: all versions of SOR and Diagonal scaling (Jacobi). Try the Vanka preconditioner/smoother instead.
or a direct solver, if possible.
Hello ERaja Ma
