Postprocessing - ploting difference in results between two time steps t1 and t2 in a transient run
In a transient runs, I need to take a difference (delta) in variable results between time t1 and t2.
Please let me know, how to do it in Comsol 3.5a or 4.0?
Thanks in advance,
Rakesh
1 Reply Last Post 2010/08/05 17:27 JST
Posted: 1 decade ago 2010/08/05 17:27 JST
if I remember right the feature to do delta time calculations has been added in V4, check the doc, I have not tried it out, I beleive too there is another Frum discussion about this, try a search
and if you do not already know there are the at() and with() operators to work on the postpocessing data, to select different times and/or eigenvalues
Hi if I remember right the feature to do delta time calculations has been added in V4, check the doc, I have not tried it out, I beleive too there is another Frum discussion about this, try a search and if you do not already know there are the at() and with() operators to work on the postpocessing data, to select different times and/or eigenvalues -- Good luck Ivar
