Parametric sweep query
Hello
I am trying to implement a parametric sweep in my model. But a problem is that for different configurations, I need to refine the mesh. For example: I have a set of electrodes and between them plasma is formed, therefore increasing the gap between the electrodes for noticing the change in plasma characteristics, I need to refine the mesh in the area between the electrode *gap*.
Can anybody please guide me if this is possible or not, when implementing parametric sweep to a model?
I sincerely appreciate your help.
Thank you
Best regards
Zaid
1 Reply Last Post 2015/06/15 8:06 GMT-4
Posted: 1 decade ago 2015/06/15 8:06 GMT-4
Firs notice that the Parametric Sweep node can lead to 2 different cases:
a) Study continuation => no need to update the geometry nor the mesh, => last results are used as initial values for the next parameter solving
b) Parametric geometry change => new mesh is generated and original initial conditions are used for each new study step
To ensure that the mesh is small enough along an edge or other elements, set up a first edge mesh with a custom size < x[mm] to be compatible with your analysis, you can also use parameters and predefined variables to define the mesh density, it's not only constant values. In this way in some critical region you can ensure a "fine enough" mesh even if the region changes shape
When doing a Parametric Sweep on the geometry, be aware that changing the geometrical Topology MIGHT give you BC id ordering issues, and your BC get defined on strangely located entities, while the geometry changes. COMSOL has been better to handle these cases efficiently, but often, still your model get messed up.
Hi Firs notice that the Parametric Sweep node can lead to 2 different cases: a) Study continuation => no need to update the geometry nor the mesh, => last results are used as initial values for the next parameter solving b) Parametric geometry change => new mesh is generated and original initial conditions are used for each new study step To ensure that the mesh is small enough along an edge or other elements, set up a first edge mesh with a custom size < x[mm] to be compatible with your analysis, you can also use parameters and predefined variables to define the mesh density, it's not only constant values. In this way in some critical region you can ensure a "fine enough" mesh even if the region changes shape When doing a Parametric Sweep on the geometry, be aware that changing the geometrical Topology MIGHT give you BC id ordering issues, and your BC get defined on strangely located entities, while the geometry changes. COMSOL has been better to handle these cases efficiently, but often, still your model get messed up. -- Good luck Ivar
