2 decades ago
2010/08/19 0:13 JST
first of all 3.5 or 4 ?
In 3.5 you can do an eigensolver then you can export the desired modes to matlab either as matrices or Silmulink I/O, but its different from Nastran, check the doc its poor (no-fwe examples) but in 3.5a you have a short chapter there.
By the way COMSOL does not normalise eigenmodes as Nastran/Ansys/COSMOS ... so the solution provided by COMSOL must be exported to matlab to be renomalise to get the mass particiaption factors out (see other discussion and script code on the Forum), such to sort out how many modes to select. Furthermore the mode export feature does only allow to select a contiguous number of modes.
In 4 I have not tested all this yet, not sure if its already fully in there.
These mode reduction issues and eigenmode mass factors are the (main) things I lack in COMSOL Structural, as the exporting to matlab only works for simple models, any "normal" engineering model is so heavy that the solution matrices saturates the RAm during the transfer to matlab
8 years ago
2017/07/06 22:52 JST
Hi all
Lets update this one :) :
New in 5.3 all "mass participation factors" are now implemented, even the rotational ones but in "beta demo" mode, and including added mass components and so.
And a solver State Space Modal Reductions nodes exist (already for several releases) to allow to export the (A,B,C,D) matrices, still I do not know of any Blogs or Application Library illustrating this for a simple example, but there are so many models out floating there, so there might be one !
Finally, the few missing items in Solid Physics, I needed, compared to the older FEM codes, are all here. These items are mandatory to allow me to show my clients the results as they are used too see them, this is essential too, even if the previous COMSOL results were just as correct.
Hi all
Henrik Sönnerlind
COMSOL Employee
8 years ago
2017/07/07 15:44 JST
Updated:
8 years ago
2017/07/07 16:34 JST
Hi Andreas,
Even though Ivar's comments contains a lot of details insight, I interpret the question in more simple way:
"How to perform a frequency domain analysis by mode superposition"
This is quite simple:
1. You add a study of the type Frequency-Domain Modal. It will contain one Eigenfrequency study step and one Frequency-Domain Modal study step.
2. You add your loads, and make sure that they are defined as "Harmonic Perturbation" (Right-click on the load in the Model Builder tree).
3. In the settings for the Eigenfrequency study step, you select which frequencies to solve for.
4. In the settings for the Frequency-Domain Modal study step, you select the range of the frequency sweep.
5. Run.
The tutorial in
www.comsol.com/model/various-analyses-of-an-elbow-bracket-4131 shows how to set up most types of structural analyses.
Henrik
Hi Andreas,
5. Run.
The tutorial in https://www.comsol.com/model/various-analyses-of-an-elbow-bracket-4131 shows how to set up most types of structural analyses.
Henrik
