Simulating a B-dependent critical current in superconductors
I had a quick look at the "ApplicationLibraries/ACDC Module/Other Industrial Applications/superconducting wire" model which simulates the time-dependent behaviour of a superconducting wire and the magnetic field penetrating into the wire. The model uses an E-J characteristic curve specified as a user function which gives 0 in case J<Jc, and a steeply rising value if J>Jc, where the critical current Jc is constant. In reality Jc is a function of magnetic field (besides temperature). Can this be added to the model somehow?
Thank you
Daniel
1 Reply Last Post 2015/11/05 4:58 GMT-5
Sven Friedel COMSOL Employee
Posted: 10 years ago 2015/11/05 4:58 GMT-5
Hi Daniel,
yes this can be done. In COMSOL any quantity (like the conductivity) can be a function of several arguments, you could define such a dependence analytically or based on table data.
Sven Friedel
Hi Daniel, yes this can be done. In COMSOL any quantity (like the conductivity) can be a function of several arguments, you could define such a dependence analytically or based on table data. Best regards, Sven Friedel
