Impulse Response of a simple structure
Hi everyone,
I would like to simulate a simple structure under the action of an impulsive force.
The structure is a free-clamped cantilever, where the impulse force is applied at the free end.
The stationary study gives no problem at all, so I define magnitude and direction of the static load and I obtain the displacement (or other mechanical parameters) of the structure.
However I have no idea of how to define an impulsive load.
I set a Time dependent study, but the load keeps being static.
I'm using comsol 4.3.
Thanks in advance to whoever is going to help :)
(I'm quite sure it's pretty easy to do, even though I couldn't find any tutorial on this matter).
4 Replies Last Post 2013/09/27 4:35 JST
Sven Friedel COMSOL Employee
Posted: 1 decade ago 2013/06/12 18:17 JST
Hi Jasha,
have a look at the tutorial "bracket transient" in the Model Library for the Structural Mechanics Module.
Sven Friedel
Hi Jasha, have a look at the tutorial "bracket transient" in the Model Library for the Structural Mechanics Module. Best regards, Sven Friedel
Posted: 1 decade ago 2013/06/15 18:38 JST
Hi Sven, and thank you for answering.
I finally managed to define an impulsive load, and I can get the time-dependent simulation to run.
However, I have another problem since comsol seems not to integrate structural friction. Any ideas on how I can introduce such mechanism?
Thank you again
Jasha
Hi Sven, and thank you for answering. I finally managed to define an impulsive load, and I can get the time-dependent simulation to run. However, I have another problem since comsol seems not to integrate structural friction. Any ideas on how I can introduce such mechanism? Thank you again Jasha
Posted: 1 decade ago 2013/09/27 4:35 JST
You can include it as structural loss factor under damping in linear elastic material.
RUBAN SUGUMAR
You can include it as structural loss factor under damping in linear elastic material. -- RUBAN SUGUMAR
Physics(Solid Mechanics)>Linear Elastic Materisl>Damping(add it) and modify the settings
RUBAN SUGUMAR
Physics(Solid Mechanics)>Linear Elastic Materisl>Damping(add it) and modify the settings -- RUBAN SUGUMAR
